Front tire for downhilling at attitash- Mtbr.com
Results 1 to 5 of 5
    What front tire would you reconmend for downhilling at attitash? The bike has an all mountain 1 fork on which i believe limits tire width to 2.8 inches and under. I would like the tire to have good turning and cornering charactics and be 2.5 inches or bigger. Weight doesn't matter since it is going to be used only for downhilling.
    Last weekend was my first trip to attitash with my jekyll I was running 2.1 nevegals front and back on azonic outlaw rims. Due to lack of tire clearance i'm stuck with the 2.1 rear. The front tire washed out alot on the expert trails at attitash and didnt turn well on rocky road due to the large loose rocks. I'm guessing that a larger nevegal would probably solve this problem either a 2.5 or 2.7. What tire would you reccomend for downhilling at attitash that fit the critaria above?
    Glad to Be Alive
    2.7 Maxxis Minion or 2.8 Michelin 32AT (might not fit)
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    Quote Originally Posted by SHIVER ME TIMBERS
    Im calling that the 2.8 michy wont fit.....
    2.7 Minion will treat you nice
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    Team
    Reputation: DHbiker's Avatar
    2.5 Michelin Comp 16.
    Glad to Be Alive
    Quote Originally Posted by j_a_k_e_69@hotmail.com
    I'd be thinkin da same
