front brake cable routing???? how??? what stem????- Mtbr.com
Results 1 to 12 of 12
    Reputation: FreerideMonkey7's Avatar
    Oct 2007
    New question here. front brake cable routing???? how??? what stem????
    How do you put the front brake cable through the stem so the cable spins with the fork???? Do I need a certain kind of stem for that??? What stems could i use??? And also can i put a gyro brake thing like bmx bikes have on my mountain bike??? Is it a good idea????? H E L P ? ? ? ?
    clyde in training
    Reputation: 08nwsula's Avatar
    i????dont??????know either??????
    Meh.
    Reputation: XSL_WiLL's Avatar
    You don't need a new stem. You need a BMX star fangled nut, a hollow compression/bearing preload bolt, and the appropriate compression cap.
    Gyros suck. Long length of housing is fine. But you would put one on a MTB just like they are put on on a BMX... same procedure... Go to your LBS. I highly doubt that you'd be able to set up a gyro correctly.
    Do you have mechanical brakes (not hydraulic) I know you can run the cable through the stem. What you need is a hollow star-nut, bolt, and top cap, I think BMX parts will work here. I don't know if a bmx gyro will work on mountain bike.
    Oct 2007
    yeah now i know i dont need a stem stupid me
    Oct 2007
    New question here.
    Quote Originally Posted by egdinger
    Why not hydraulic brakes???
    Meh.
    You can still do it with hydraulic. You've just got to take it apart and rebleed.
    Using a mechanical puts some funky bends in the cable routing. So the lever might feel like crap.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Even if you can get a gyro fitted on the bike there isn't enough cable throw to get the brakes to work right. I tried it on my BMX with V brakes and it was terrible, all mush and no stopping power.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Bike Ninja |||
    Reputation: chooofoojoo's Avatar
    Feb 2007
    Quote Originally Posted by 08nwsula
    Proud to represent Mojo Wheels.
    Meh.
    You can make a BMX lever to the BB7 Road with a gyro. It's pretty similar to using the same pull ratio.
    Oct 2007
    Quote Originally Posted by jamesdc
    Thats funny i was looking on that website the other day I was gonna ask about these parts thanks anyway
