Frame cracked due to winter riding? :-)- Mtbr.com
Results 1 to 18 of 18
    G3Riders
    Hello,
    Just stupid (or not?) question wich raised my friend and we argued a lot abou it:
    "is it possible that frame/weld on frame cracked due to riding in lower temparatures"?
    My friend does not ride in really low temparatures - just -5 Celsius.
    Here's photo of crack.
    I know most of you probably don't ride in snowy conditions, but just wondering if cold weather can contribute to weld cracks.
    Former Noob Herder
    Reputation: zedro's Avatar
    normally no the temperature isnt low enough to make the aluminum brittle. But if there was some internal stresses already present in the metal, the contraction could promote a crack ontop of the normal riding stresses; but this is a case of a frame defect anyways.
    Look at it this way: airplanes fly in much colder temperatures and they are mostly made from aluminum.
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Feb 2005
    Quote Originally Posted by zedro
    The cold could affect, or crack your frame. Airplanes are made of Aluminum, but they are designed to take the low tempters of the altitude. Sorry to hear what happen.
    V10 Freerider
    Reputation: Frankenschwinn's Avatar
    not unless by winter you mean abuse... It would take some pretty seriously low temps to have that kind of effect
    The Super T you have is really a very good fork. I'd take that fork over a Fox 40 or a Boxer unless i was entering a fashon contest instead of a race
    Former Noob Herder
    Quote Originally Posted by kiko77
    we're talking about -5C here, not -50....
    -arschloch-
    no
    in general, the yield and fracture strengths of aluminium (and other metals like it) are pretty insensitive to temperature.
    bummer about the frame. what was it?
    To air is human, to dig is divine.
    Xtremely Moderate
    Reputation: e<i>o's Avatar
    Hey hey hey! .....speak American here....... F not C!
    "Korash your enemiez, zee zem driven bevore you, and ear ze lamentation of za vemen"
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    Quote Originally Posted by e<i>o
    here you go
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    Xtremely Moderate
    Quote Originally Posted by [email protected]
    here you go
    Ahhhhhhh that's better. Thanks.....
    As an American I get very freaked out by Celsius and Metric.
    Former Noob Herder
    Quote Originally Posted by eo
    yeah, celcius is so complicated. Water freezes at 0, water boils at 100....
    VIA
    VIA is offline
    Reputation: VIA's Avatar
    Don't know buy my frame sems to be more afected by the worm weather since always crack on summer...
    I think it would be too cold for you to ride before it would be cold enough to make the aluminum brittle. The main body of an airplane is made out of very similar grades of aluminum as bike frames, so I think zedro makes a good point. It think natural stresses or a frame defect just happened to have done your frame in during the winter. 20F/-5C is really in the normal temperature range that we would expect a common structural metal to hold up in.
    Xtremely Moderate
    No no no..............32 & 212. Those are much easier to remember.
    I am American therefore you must do things my way.
    Even if its contrary to the way the rest of the world does things.
    G3Riders
    Frame is A-Zone by Author (CZ)
    Quote Originally Posted by chuffer
    That's my freind's freeride frame from Czech Rep. called Author A-Zone. They're quite cheap in Europe and unfortunately their rear triangles used to break sooner or later. Design's fault I suppose.
    May 2005
    yeah, tell me about it...
    Reputation: Prechrysler's Avatar
    haha!
    Sep 2004
    As stated, aluminum is very resistant to becomming brittle...unlike steel.
    I saw a domonstration once...two dowel pins were put in liquid nitrogen, one steel (low carbon), one aluminum. Both were hit by a hammer....the steel shattered, the aluminum bent
    /dev/null
    Reputation: binary visions's Avatar
    I think threads older than two months should require a moderator's permission before you post in them.
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. Replies: 5
    Last Post: 10-27-2004, 11:39 AM
  3. comparison of ProPedal, Float and ALPS on same frame
    By ccm in forum Shocks and Suspension
    Last Post: 06-15-2004, 08:37 AM
  4. cracked Ti frame
    By otismojo in forum General Discussion
    Last Post: 05-10-2004, 06:53 AM
  5. Another cracked frame
    By mountaingoatepics in forum Diamondback
    Last Post: 04-15-2004, 04:19 AM
