fram/ shock ahahh answer my question plz- Mtbr.com
Results 1 to 15 of 15
    Reputation: azonicrider188a's Avatar
    Mar 2006
    ok i am about to by a kona stink primo and i am wonder were icould get the axle or what ever it is called for the shock that i will buy soon also. as u can see from the picture it is not there. i probley gonna bye a swinger 6way and is there somthing special i will need for the frame to moint this shock. also it does not come with bushings so i could just order thoose from the company right?
    Signatures are for losers
    Reputation: freerider167's Avatar
    Dec 2004
    it's a bolt.. you can easily pick one up at the LBS or local hardware store. just make sure it's a strong bolt
    Mar 2006
    what u mean a "bolt"
    e.f.f.e.c.t smoothoperatr
    Reputation: themarsvolta55's Avatar
    Dec 2004
    a normal frikin bolt derek! i already ttold u there like A BUCK , 1 dollar, numero uno dolaarre.
    Mar 2005
    you need the spacers for the shock.
    Whoaohohohoh
    Guest
    Kona should have the hardware you need and manitou should have the reducers you need to mount that shock to your frame.
    Jun 2005
    yeh but remember to go to the frame spec page and find the standard eye2eye length before you buy
    best
    Reputation: Amazing Larry104's Avatar
    Aug 2005
    yea, you will proabably need new reducers unless the shock is from a similar bike and has them still in it,maybe they will possibly fit. you can get those online though so its not bad. and you can just buy a bolt to go through the hole and mount it
    IS THIS SOMETHING YOU CAN SHARE WITH THE REST OF US AMAZING LARRY ?!?!?!
    aircooled VW FTW
    East Coast Style
    Reputation: acdcfan1283's Avatar
    um...youre putting a 3.0 stroke shock onto that? correct me if im wrong, but isnt the shock sizing like 2.5 stroke? i know the regular stinky is 2.3 stroke (2004), so im assuming that since it has 1 more" of travel there might be just a little bit more stroke. I'd reconsider that shock...
    Intense Socom
    Transition Double
    [/SIZE][/FONT]
    Freeriding Feline
    Reputation: SuperKat's Avatar
    Mar 2005
    Themarsvolta made me laugh!
    "If you give up your dream, you die."
    Twitter - KIKat1029
    Dec 2004
    muahaah
    niko still has the bolt on his stinky, d!ck...
    hey i need some advise. I am considering buying a azonic fiend frame. I just want to know if anyone has heard anything good or bad about that frame.
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    Quote Originally Posted by kicker66609
    Be more specific, and start your own thread.....
    You should at least have some idea of how the forum works before you post....
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    Reputation: standard235's Avatar
    Or at least a brain in your head.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Quote Originally Posted by [email protected]
    Make as many posts as possible with the least amount of coherence as possible. If there is an oppurtunity to cause confusion or spread misinformation, it must be exploited. Flame out people. Argue about what's best. Argue how big a drop is. Photoshop stuff.
