Fox DHX Coil Rebuild Guide - Version 3- Mtbr.com
Results 1 to 36 of 36
    Reputation: Nick_M2R's Avatar
    Hi all
    Here is my promised update to my old Fox DHX rebuild guide
    Ive included more pics, altered the procedure to make it easier, as well as to keep inline with some new info i learned since writing my first one
    Ive spell checked this one much better than the old one (please remember though, im only human, and its late at night )
    Also i used much clearer, higher quality pictures that have been taken with my dads Nikon D200 DSLR camera with a big mofo of a lens, instead of my camera phone
    However the original document was over 200mb and when i converted the file to a PDF, its downgraded the quality of the pictures slightly. the pics are still easily understandable, so consider this a preliminary release until i get this sorted
    Yes its uploaded to media fire, deal with it people
    Also coming soon
    A high quality video showing you how to rebuild the shock
    A file containing high resolution shots, to be used in conjunction with the original V3 guide, should you want to look at high res pics of the process
    Please remember to read it throughly before carrying any work out on your shock
    Anyway enjoy guys and girls!
    Heres the link to the file, remember its preliminary until i can get the picture quality sorted
    http://www.mediafire.com/?sharekey=7...db6fb9a8902bda
    Enjoy!
    Jan 2005
    very nice work..thanks
    "He can make even a global summit meeting seem like a kegger." M. Dowd, NY Times, 19 July 2006
    I bike long tyme.
    Reputation: Secace's Avatar
    Sep 2004
    Very cool!
    People wait for me on the way up. I wait for them on the way down.
    Bum Buzzer
    Reputation: Huck Banzai's Avatar
    May 2005
    Pants!
    squish is good
    Reputation: Clutchman83's Avatar
    Good stuff, keep it up Nick!
    Bike good, work bad.
    Great guide. I will be overhauling my dhx later in the season. This will come in very handy. Thanks for taking the time to do it right and post it up.
    moaaar shimz
    Reputation: tacubaya's Avatar
    Veeeeeeeery nice, thanks.
    Fat Guy Riding
    Reputation: jschwart73's Avatar
    Awesome guide, used it tonight to fix my DHX 5 that had gotten a little air in it. It's silky smooth and back in action. Thanks!
    Quote Originally Posted by Empty_Beer
    A bike company should come out with a bike named after Mikey. the Santa Cruz Vandeman. That would pisss him off to no end.
    Great to hear its working for you guys!
    Tonight i just finished the video that is to be used in conjunction with the PDF guide, all i need to do is the voice over, but i cant do that yet as ive caught a cold and can barely speak.
    Then just got to finish up the picture file that contains higher res pictures of the pics in the PDF file
    Hope you guys and girls will like it
    Hey, great job! and thanks!
    -Ryan
    -polished SC Bullit .2
    -handbuilt 29er rigid
    O-rings for servicing Fox DHX coil shock.
    Nov 2008
    Thanks for the info! I'll try it later in the season.
    Reputation: Mountainbikextremist's Avatar
    Jan 2005
    Great guide! Do you have a close up shot of the shaft shims, because I think I might have mucked them up like you warned against. Also, I seem to be having difficulty getting a good bleed. I tried your technique, and also fully submerging it in oil. I think I am getting a small bubble that gets trapped when Im screwing the shaft back in. I get an audible squish at the very beginning of the stroke, and doesnt return when I am continually cycling the shock. Thanks!
    If I want your opinion, I will give give it to you...
    You got like 3 feet of air that time... -Napoleon Dynamite
    Quote Originally Posted by Mountainbikextremist
    Regarding the bleed did you make sure that you filled the piggyback resi and main resi fully? meaning that the oil is pretty much overflowing. PLace the IFP in the resi (with bleed screw inserted) hold it in with you thumb while placing the shaft into the chamber. The reason you have to make sure that both are almost overflowing with oil because when you screw in the cap, oil will overflow and bring with it any air trapped in the threads. Once youve screwed in the shaft, remove bleed screw from IFP and push it to the correct depth (watch for oil that squirts out!), making sure you tap the shock to displace any air. This is how ive done the bleed procedure and everytime its worked, you may get a tiny squelch when you first cycle the shock, but it goes away after that, just make sure you take your time
    As for the shims, here is the only picture i have of the stack (for a 09 DHX) at the moment
    The Washer on the far left is the thick black back plate that goes on the bottom of the stack, between that and the piston is the compression stack, then on the otherside of the piston is the rebound stack.
    Hope this helps ya mate
    I wonder if anyone has tuned the shim stack yet on their own, and also found a supplier for this size and thickness.
    From what ive heard alot of people say, mxtech has the shims
    Thanks Nick this guide will be very helpful and is much appreciated.
    Jan 2005
    Dowt!
    I think I just may have noticed why my DHX has been such a pain to bleed, and the rebound knob increases compression rather than rebound...shim stack probably is in upside down I will proceed to do tear down #3 tomarrow evening.
    Yes that may well be the cause haha
    Let us know how it goes!
    Actually, I'd like that if the PP knob would work the rebound because I typically want to change that setting during a ride without stopping more than compression.
    Has anyone rebuilt a PUSH'd DHX?
    Jan 2005
    Yes sir that was the problem, my shim stack was in upside down. Damn, they are a mess to service! She is pure butta now though!
    Great to hear it worked out for ya mate!
    Flying High Again
    Reputation: Ripzalot's Avatar
    nice work, thanks for posting!
    Almost got the video finished guys and girls
    Ive also finished the file with higher quality pics to be used in conjunction with the guide
    Hope to have it all up by next weekend
    Stay tuned!
    Premium Member
    Reputation: Ojai Bicyclist's Avatar
    Any word on the update? Just got my O-rings in today and I'm excited for a rebuild!
    Yep the file containing the high res pictures is up
    Unfortunantly my video decided to corrupt itself and im having a HELL of a time to try and fix it up, but i am working on it!
    Here is the link to my thread which is where everything regarding a DHX rebuild will be posted, hope you like it!
    http://forums.mtbr.com/showthread.php?t=538515
    Premium Member
    Cool, thanks. I just did mine today and unfortunately it's stuck down though - not sure if it's a bad O-ring or if it's a problem w/ bleeding - any tips on how to get the shaft inserted w/o leaking fluid out of the reserviour by the IFP? Should the IFP get pushed down a little further?
    Problem you seem to be having is in step 9 and 10, are you sure you followed these bits correctly?
    The only reason i can think of that is causing fluid to leak out of the IFP as you reinsert the shaft is because you havent either put the bleed screw back in or the O-rings on the IFP may have been damaged when you installed them or their the wrong size. If you measured the IFP depth at the start and reinstalled it to this depth at the end, there is no need to change the depth, if in doubt check the chart. You must hold the IFP at its depth when you reinstall the piston, as when you screw it in, oil will overflow from the black end cap, which will push out any air trapped inside.
    Hope this helps, but make sure you followed step 9 and 10 correctly
    Premium Member
    I put the bleed screw in, did the depth, etc., etc. Tried 3 bleeds today. I think the problem occurs when I push the shaft assembly into the main chamber? The shock feels fine except for about 1/8" of dead travel (no damping). Gonna take it to someone w/ more experience than me with shocks tomorrow to see if they can figure it out. I should double-check the IFP O-ring as well.
    Would cycling the shock w/o air in the boost valve upon completion hurt anything? I ask because I did that to see if it felt alright before airing it up to 125 PSI, then realized after that was probably a stupid thing to do.
    Hmm either you have a massive air pocket in the damper (which i highly doubt) or there is something wrong with your compression assembly, have the people you take it to check the compression assembly
    Premium Member
    The only place that seemed to me like it could be a problem was threading in the shaft assembly - it displaces a lot of oil putting it in, and maybe I spilled too much out of the body or something? I'm taking it to someone soon here to have it checked out...
    A large amount of oil will spill out, as the piston and seal head will displace the oil that sits in the top of the main resi when you fill it to the point of overflowing
    Natl. Champ DH Poser/Hack
    Reputation: cactuscorn's Avatar
    nice! she be bookmarked.
    No, I'm NOT back!
    Quote Originally Posted by Ojai Bicyclist
    and then compressed the piston (once) to check for clearance putting the shock on a new frame. Did I kill the shock? Do I have to tear it down and do a bleed now, or is one silly mess up not going to do anything?
    If you compress the piston without air in the boost valve, is there anything special you have to do, besides never do it again?
    thanks guys, I'm bumming.
    Unless you here squelching noises from inside the shock, just inflate it back up, there will always be abit of air in the boost valve, unless you pull a vacuum on it.
    If you here squelching noises from your shock, the oil has air in it, meaning it will need to be bleed. Follow my guide to change the oil, just ignore the bits showing how everything is taken apart
    thanks so much nick, I appreciate it. Not really squelching anymore. Did you mention what weight/kind oil to use in the procedure? Also, are there any little mods I can do when I'm in there to make things a bit more plush?
    Hunter
