Few Tech Questions- Mtbr.com
Results 1 to 10 of 10
    New question here. Few Tech Questions
    1. When installed a 20mil. axle into the hub should I grease it?
    2. Can I install the crown race with a pipe and creativity?
    3. For a singlespeed setup what gearing would you reccomend.
    I plan on either-
    32-16
    32-14
    38-?
    I hope to use the smaller front ring and I need a lot of speed because you gotta crank pretty hard to clear my jumps. In other words I am more concerned about top speed.
    Former Noob Herder
    Reputation: zedro's Avatar
    1. no not necessary, and would just be messy
    2. yes, even a screwdriver is fine as long as you tap evenl
    3. dunno, my SS setup was a complete failiure for anything but snow drenched roads
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    i should be working
    Reputation: rpl3000's Avatar
    32-16 shoulde be fine.
    Quote Originally Posted by zedro
    sounds good
    thanks
    Quote Originally Posted by rpl3000
    Yea I am going to try the 16 and 14 rear and see how it is. i may just throw the cassette back on if i don't like it
    Reputation: VooDoo13's Avatar
    Jan 2005
    Quote Originally Posted by MX 887
    sounds good
    thanks
    I'd use the pipe and heavy hammer trick....that's how I got mine straight. Just pull the pipe off and check to see it's going on straight every couple taps. Worked well for me.
    You have bleed with Wallace.....now bleed with me!
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    1. I was always told to put a tad bit of grease on the axle.... I can see how it would be nessecary, and how it wouldnt... its your call..
    2. after reading that question over and over I still dont understand it...
    3. 32/16 is about right....
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    pwn3rator
    Reputation: scabrider's Avatar
    no...
    pipe...
    34:16...
    SOCAL UNION REPREZENT
    Quote Originally Posted by JBsoxB
    does it still qualify as a mountainbike?
    Quote Originally Posted by kidwoo
    I've beat beer cans on my limp pee pee.
    Meh.
    Reputation: XSL_WiLL's Avatar
    There's no need to grease the axle.
    You can install the crown race using a hammer and a screwdriver, just make sure it comes down evenly.
    With SS, try running twice as many teeth up front as you have in the rear. And then play around with it from there. Atleast that's how I always figured it out on my BMX bikes.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    no....
    you're supposed to smoke with the pipe, not bang on it........
    the closer to a 2:1 ratio the better.......
  1. WTB: black Machine Tech brake levers
    By uphiller in forum Vintage, Retro, Classic
    Last Post: 07-06-2005, 06:36 AM
  2. Incoming Virginia Tech Freshman, you're invited to join our biking club.
    By Cerna in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 06-23-2005, 04:24 PM
  3. VPX build questions
    By tep in forum Intense
    Last Post: 05-04-2005, 09:34 AM
  4. Opinions on Control Tech product needed
    By TomFL in forum Weight Weenies
    Last Post: 04-30-2005, 05:43 PM
