Results 1 to 2 of 2
    Reputation: mrpercussive's Avatar
    Falling Rate Suspension Vivid R2C
    So I've got 2008 Mongoose EC-D with a Vivid R2C MM... It's a falling rate design... would running more sag and higher lo speed compression help make it more progressive? Pardon the noobness...
    https://www.instagram.com/p/BjgDWeKlcDc
    mbtr member
    Reputation: scottzg's Avatar
    The linkage is a falling rate and nothing will change that. Adding more LSC will make it use travel less readily. Adding volume reduction bands will increase spring rate, especially at the end of travel. More sag just reduces spring rate.
    You need to describe what your issue is.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
  1. Shock question: Vivid Air R2C or Vivid Coil R2C on 2015 Giant Glory 0
    By dasnakenyc in forum Shocks and Suspension
    Last Post: 08-11-2015, 10:01 AM
  2. TNT RFX: rising or falling rate?
    By bugaroo in forum Turner
    Last Post: 05-09-2012, 10:22 AM
  3. Replies: 1
    Last Post: 04-08-2011, 04:13 PM
  4. Vivid air R2C for placeholder arrives!
    By El Chingon in forum Turner
    Last Post: 02-18-2011, 08:50 AM
  5. Anyone running a 2011 RS Vivid Air R2C on HD?
    By gearhunter in forum Ibis
    Last Post: 02-01-2011, 08:37 PM
