Electrical Tape for Rim Tape??- Mtbr.com
Results 1 to 22 of 22
    Jan 2005
    Is it ok to run a few laps of electrical tape on my rim instead of regular rim tape? Is real rim tape better for any reason (lighter?)?
    Cynical Bystander
    Reputation: COmtbiker12's Avatar
    I've used electrical tape in the past. Works just fine.
    Tony
    is making a comeback.
    Turns out that five years of not mountain biking, really makes one strive to get back to it.
    tlg
    tlg is offline
    (enter witty phrase here)
    Reputation: tlg's Avatar
    Quote Originally Posted by dandurston
    Sure. One layer is enough. Overlap a few inches. I've used it for several years with no problem. It also helps seal out water and dirt from getting in through the spoke holes. I've also noticed that after getting a flat the air leaks out slower. "Real" rim tape is heavier.
    (This is assuming your spokes don't protrude into the tube area, done on cheap rims. If so they'll poke through electrical tape.)
    Reputation: 006_007's Avatar
    Only problem with electrical tape is it is fairly flexible and over time will collapse into the spoke holes.
    I would recommend using filament tape (or fiber tape). Can be found at hardware stores and is cheap. Also is supplied in Stans no-tubes kits.
    high plains drifter
    Reputation: mateoway's Avatar
    multiple uses
    I once witnessed a guy shred his sidewall and we wrapped electrical tape around the tire through the spokes and rim to hold the tube and tire to the rim and he rode 13 miles back to the truck.as long as it keeps the tube from rubbing the spoke holes anything would work
    Quote Originally Posted by mateoway
    Wasnt there something like that in last months MB action?
    New project, TBA shortly
    Reputation: dante's Avatar
    electrical tape, packing tape, duct tape, hockey tape (don't recommend), just about anything can be used. it's when you get to road bikes with 120+psi that you start needing to worry about the pressure poking through the spoke holes.
    Glad to Be Alive
    I vote for duct tape and Pedro Sanchez
    Jan 2005
    Thanks guys, I already wrapped it around 3 times. I just gotta decide if I'm ambitious enough to take apart the wheel and reduce it to one layer.
    Old school BMXer
    Reputation: Blaster1200's Avatar
    I've blown a tube with electrical tape as rim tape.
    I had two wraps around the rim, and I had it there for at least a year prior. Over time, as 006-007 mentioned, it stetched and eventually allowed the tube to burst through the hole. It was clearly evident what happened when you looked at the tube. While electrical tape works in pinch for a short time, I'd recommend using some kind of fiber-reinforced tape.
    Tear it all out! SuperModerator
    Reputation: CraigH's Avatar
    2nd the glass filament tape. I've used it for years with no problems.
    Jan 2005
    Is that fibre tape like masking tape or a totally different thing?
    different. It has fiberglass strings that run along the length of it making it very strong.
    Do a google search for "filament tape" or just pop into your local hardware store.
    TJ
    Jan 2005
    Quote Originally Posted by 006_007
    Different. It has fiberglass strings that run along the length of it making it very strong. Do a google search for "filament tape" or just pop into your local hardware store.
    TJ
    Ok, I'll pick some up tomorrow. Thanks! Is one layer enough?
    There's no app for this.
    Reputation: JimC.'s Avatar
    Yabut
    with electrical tape you'll never get a short!
    Hmn, think I better get some of that fiberglass tape and put it on the Knolly, what's another few grams of tape?
    Jim
    I use two layers.
    It is also called strapping tape. (But the narrowest roll you can find, 1/2" or 3/4")
    One other good thing about this tape, is that it is easy to rip to the correct width if you are using it on a narrow rim.
    One layer is plenty strong. Just make sure it overlaps @ 1.5-2".
    Quote Originally Posted by JimC.
    Jim
    You are not running any rim strips in those wheels Jim?
    If you are interested I am gonna convert mine to tubeless this weekend (providing I can get away from work for a spare 5 minutes....)
    TJ
    Reputation: Dougal's Avatar
    I've used electrical tape exclusively on my wheels for 10 years.
    I run two layers (don't stretch it too thin) and haven't had a problem with it running up to 50psi.
    Owner of www.shockcraft.co.nz, Mech Engineer, Tuner, Manitou, Motorex, Vorsprung EPTC, SKF, Enduro
    www.dougal.co.nz
    Some Assembly Required
    Reputation: man w/ one hand's Avatar
    I keep duct tape wrapped around my pump handle for emergencies.
    "Why are you willing to take so much & leave others in need...just because you can?"
    go big or go home
    Reputation: bentimby's Avatar
    or duct tape...just get a rim strip
    pedaller
    Reputation: Noelg's Avatar
    Nice avatar!
    "Nobody ever told me not to try" - Curious George Soundtrack by Jack Johnson
  1. Stans ZTR Olympic/ 355 rims
    By redrock_z71 in forum Wheels and Tires
    Last Post: 03-30-2006, 11:01 PM
  2. What tape to use when reusing Eclipse rim strip?
    By schnapmaster in forum Wheels and Tires
    Last Post: 01-15-2005, 12:40 AM
  3. Advice with Stan no tubes sealent ?
    By Johny Rotten in forum Singlespeed
    Last Post: 02-13-2004, 03:39 PM
  4. time for lightweight rim tape....
    By danK in forum Weight Weenies
    Last Post: 01-28-2004, 07:06 PM
  5. Suggestions for WW FAQ section
    By Trevor! in forum Weight Weenies
    Last Post: 01-19-2004, 01:22 PM
