E13 DRS for Kona srinky 08- Mtbr.com
Results 1 to 7 of 7
    SHR
    SHR is offline
    Nov 2008
    Hi!
    I just got my first FR/DH bike and I can use a Chain Guide...(dual ring)
    Dose anyone know if E13 DRS will fit to Kona Stinky 2008?
    http://www.e13components.com/product_drs.html
    also, I dont know what is the meaning of "4x104 bcd"
    For The Win
    Reputation: StinkyFTW's Avatar
    I believe you will need an ISCG adapter plate. But yeah, it should work.
    Slow is cool too, right?
    Oct 2007
    no need for the adapter plate...i have the howitzer external bb and use that to hold my chainguide on...kinda janky but there are no iscg plates for my blitz
    I'd huck that...
    Meh.
    Reputation: XSL_WiLL's Avatar
    You need the ISCG/e-type adapter if you intend to use the ISCG backplate. There's also a e-type version.
    4x104BCD is the mounting pattern for the chainring/bashguard.
    SHR
    SHR is offline
    Nov 2008
    Another brands
    Thanks you all for replying!
    I just saw that the e.bay sale is close to the NEW retail price (for used equipment).
    Is there another brands for chain guides that are work well with dual plate?
    what are the difference between the two:
    MRP LRP Alloy ISCG 05 chainguide, 34-38 tooth
    Bicycle Bike Double Chain Guide Adjustable New ISCG
    thanks!
    Former Ninja
    Hey SHR,
    I'm pretty sure that up until 09 the Stinky doesn't have ISCG tabs at all. My 06 sure doesn't have tabs.
    You essentially need to order up the ISCG-OLD version of the DRS. The ISCG-OLD backplate is also bottom bracket mount compatible, so that it will replace your drive side 2.5mm bottom bracket spacer and clamp down between the BB cup and the BB shell.
    The DRS won't work with an ISCG adapter, because the adapter adds 5mm of width to the guide setup. This will cause the granny ring bolts to bottom out into the backplate when you try to reinstall your cranks.
    This is all outlined in the instructions included with the guide, so everything you'll need is right there.
    Hope this clarifies things!
    Cheers, philip
    SHR
    SHR is offline
    Nov 2008
    Thank you
    That was very useful information!
    Sincerely,
    SHR
