e13 drs on a demo 8 problem?- Mtbr.com
    Apr 2005
    hey, so i am trying to mount my drs, and have found that it is spaced wrongly with the wide bb of the demo eight. it is two far towards the none drive side of bike to shift into bigger ring. i have it mounted as e type, as i do not the the iscg stuff for it. anyone else have this problem? or know of what i could do to use it? o also no bashing or heckaling for running a dual ring on a demo. i ride to get to the top of my hills!!! thanks in advance.
    they call you a gansta if you spend big bucks on a pair of 20" chromes. well shlt.... i got a pair of 26's!
    conjoinicorned
    Reputation: ferday's Avatar
    i have a balfa 2step, not a demo....but i had a similar problem, the dremel and a new set of 3 piece cranks solved the problem. the 3 piece are the only way (for me at least) to get the spacing the right way.
    what would rainbow unicorn do?
    Huh?
    Apr 2005
    E-mail or call E-13 directly they will guide (pun intended) you.
    http://www.e13components.com/support.html
    Sep 2004
    D-R-E-M-M-E-L!!!+patience =drs that works
    It puts the lotion in the basket or it gets the hose!
