Dual crown fork install on 1.5 headtube- Mtbr.com
Results 1 to 12 of 12
    Dual crown fork install on 1.5 headtube.
    The frame (Trek Session 7) has a straight 1.5 headtube. Dual crown fork (Marzocchi 888) has a 1 1/8" steerer tube. Frame currently has a Bontrager Big Earl headset in it (for 1.5" steerer fork).
    What do I need to make this work? Do I need to locate a 1.5-1-1/8 reducer headset, or can I buy reducer cups and use most of the existing headset.
    Any suggestions on parts? FSA Orbit headsets/reducer cups still seem to be available.
    Professional Troll
    Reputation: Gemini2k05's Avatar
    Apr 2005
    Just buy a cane creek reducing headset.
    Quote Originally Posted by Gemini2k05 View Post
    Sadly, those don't seem to be available anymore.
    After some searching, I think I've figured out how to do this :-
    Either :-
    1. buy a reducer headset
    or
    2. buy reducer cups, and buy a 1-1/8" headset.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Chris King Devolution headset. It just uses a different baseplate to adapt the 1.5 cup to a 1 1/8" steer tube.
    https://www.chrisking.com/product/devo-baseplates/
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Another thing to be aware of is if your frame has a tall head tube, like many older DH bikes do, you can get the King Inset 4 to reduce the overall stack height. That's what I ran on 2 generations of V10 till this most recent one that has a shorter head tube.
    Straight 1.5 head tubes on DH bikes are kinda nice for this versatility.
    Quote Originally Posted by IntenseMack10 View Post
    I'm not sure I understand how this would work. From the CK website - "The Chris King InSet™ 4 is designed for 49mm headtubes and 1-1/8”steerer tubes commonly found on dual crown forks".
    Now my steerer tube is 1.5" which I think would make it about 38.1mm (25.4mm in an inch, 25.4 x 1.5 = 38.1) Just guessing that, I can't really measure it as there is a fork installed in it at the moment). How would a 49mm Inset 4 headset fit in a 38.1mm diameter part of the steerer tube? I'm sure I'm missing something.
    And, do you use the Inset 4 in place of the Devolution or in conjunction with some parts of it?
    Reputation: Joules's Avatar
    49mm is the ID of your head tube, which fits a 38mm steerer. You are trying to install a 28.6mm steerer in the 49mm head tube, this leaves enough room to put the bearings inside, which reduces overall height.
    Inset or Devolution is either/or, not both. There are cheaper options also; Cane Creek ZS49 is less than a third the price of the king. An FSA orbit reducer runs $38 at Universal.
    Professional Troll
    Apr 2005
    Quote Originally Posted by scrutton View Post
    Just checked their website, definitely still availble to find a headset that lets a 1-1/8 fork fit in a 1.5 headtube frame.
    Don't ever quesiton me again.
    Reputation: Flamingtaco's Avatar
    Mar 2012
    My solution was to keep the headset and use a piece of 1.125id x 1.50od aluminum tubing so I wouldn't have to replace the spacers and stem as well. 3ft was $20 shipped. Cost will be $5 once I sell off the rest.
    I will suffer no butt-hurt fools!
    Hope no offense was taken. I think I was confused with regard model names. Appears that the 40/110 series would work and these are still in production.
    Your bike sucks
    Reputation: Carl Mega's Avatar
    I did this last season...ebay for $60 - Cane Creek 40 Series Conversion ZS49/28.6 ZS49/30
  1. dual crown fork on a xc mtb
    By RheXtian in forum Bike and Frame discussion
    Last Post: 01-23-2017, 10:56 AM
  2. best fr/dh dual crown fork under a grand?
    By DeathWish in forum Shocks and Suspension
    Last Post: 01-09-2014, 04:01 PM
  3. Replies: 2
    Last Post: 07-22-2012, 05:16 AM
  4. recommend a dual crown fork
    By rdhfreethought in forum Knolly
    Last Post: 05-02-2012, 04:21 PM
  5. Amazing dual crown fork
    By Mr.Dman in forum Downhill - Freeride
    Last Post: 01-14-2012, 01:25 AM
