Which dual crown fork?- Mtbr.com
Results 1 to 6 of 6
    Dec 2009
    Okay, I've been riding my 2007 transition gran mal for some time now and I'm really starting to like the bike so I thought I'd upgrade the fork to a 200mm travel one. I've been running 9,5" x 3 marzocchi roco at rear (frame adjusted to about 185mm of travel) with 66 RCV fork. I'm a bit heavier rider, about 230lbs which makes about 240 - 245lbs with all the gear on. Mostly I ride downhill with small jumps and repeated hits, rock gardens etc.
    So my question is should I get boxxer or 888 or something else?
    tbh, either will be fine..
    u can get some amazing deals on either too
    beware of 08-09 888s though
    Dec 2009
    Well about that 08 - 09 thing, I've been using my 2008 66 RCV for more than a year now, and can't complain much, rebound and compression adjustments works well and the air preload also is pretty simple, quite simple fork all in all. Once I've changed the fork oil and dust & oil seals, allthough the fork was working nice.
    Rider, Builder, Dreamer
    Reputation: sambs827's Avatar
    Dec 2008
    Used Fox 40?
    Go ride your bike.
    bike rider
    Reputation: Lelandjt's Avatar
    2010 888 EVO with stiff spring.
    Keep the Country country.
    Glad to Be Alive
    match the shock with the fork
