Drivetrain issues- SRAM/Wipperman Chain- Mtbr.com
    Hey dudes,
    I was hoping I could get some advice on some drivetrain issues. I've got a truvativ stylo crankset/rings with a 990 cassette and I'm using a wipperman chain. I'm only using the wipperman because I broke my SRAM 971 chain. The problem is the lowest gear keeps popping under power. Very annoying. Anyone had problems with these chains? Maybe I should have stuck with the crappy Z chain the bike came with! Thanks.
    Reputation: SFBMRC's Avatar
    is it popping with every pedal revolution or every once in a while. also, which gear combo are you talking about?
    Meh.
    Reputation: XSL_WiLL's Avatar
    If you are using the Wipperman quick link, switch the orientation. If it's not facing the right direction, it won't mesh correctly with the 11t.
    Thanks XSL. I hadn't thought of that. I had a feeling it might be the quicklink but it's hard to replicated on the stand and you can't see it while pedaling. However, I put on a Sachs PC41 I had new in a box just lying around and it was like butter. So much better. I'll try it out. The wipperman still had issues shifting as well.
