dremel off ISCG tabs = bad idea?- Mtbr.com
Results 1 to 7 of 7
    Chillin the Most
    anyone ever done this? any problems, besides the possible voided warranty? I'm worried more about structural issues really. I don't forsee any, but figured best to get a consensus. The ones on my Big Hit aren't aligned right and it makes setting up guides a PITA. Thanks.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    consider them gone, i would..........
    Former Noob Herder
    Reputation: zedro's Avatar
    just make sure there arent any jagged parts; sand everything down real nice.
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Dumb question.
    Quote Originally Posted by red5
    I mean, obviously the frame manufacturers know better (???), but what was wrong with the chain device just being clamped behind the BB? I know the device could turn if struck just right, but that would seem less catostrophic than the alternative. Keep in mind that the only exposure we've had at the shop is installing an LRP on a Gemini. It was a pain requiring spacing and such for those tabs to get a proper chainline. I'm sure there must be some actual benefits of the tabs, but I haven't had enough experience with it.
    I think having it clamped in with the BB is infinitely better as well. My view is that having it on the BB is kind of like having your brake levers set up such that they turn on the bar in a crash rather than breaking or bending. It shouldn't normally be an issue, and it gives you that extra security just in case something bad happens.
    Also, correct me if I'm wrong, but I also thought that a while back, the E-13 guys mentioned that they were planning on doing away with ISCG mounting and fully going with the BB mounting approach...not sure but for some reason I seem to remember this.
    I had to do that to one of my frames as the mounts were in the wrong position... If it was a new frame, I probably would have sent it back, but this was a demo I had picked up so I was out of luck... Lucky for me the mounts were not actually part of the BB shell, but on a small ring welded to the shell with 3 small tack welds. A little dremel action and a tap of a hammer solved the issue... But on my Mountain Cycle, the guide mounts were set right and my Evil guide went on perfectly according to the directions....
    Brian
    Shiveriffic
    Reputation: Mr. Grimm's Avatar
    Gooooonnnnnnnnnnneeeeeeeeeeee.....................
    I had the same problem with my frame..... The welds on the bighit frame are beautiful (mainly because they are robot welds), but the welds on the tabs are terrible... I think the guys who were welding the tabs on were drunk... Getting rid of those things will clean up your frame... I was able to get mine to work with my evil DRS and suffered the consequences for using them, your best off to go with the BB mount, replacing the guide frame is expensive!
    ~Gary
  1. Mountain Bike Spring Rate Calculator V5.0
    By FireDog46 in forum Shocks and Suspension
    Last Post: 07-16-2013, 08:46 PM
  2. Mountain Bike Spring Rate Calculator V4.0
    Last Post: 02-29-2004, 07:34 PM
  3. Mountain Bike Gear Ratio Calculator V4.0
    By FireDog46 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-29-2004, 11:57 AM
  4. Mountain Bike Spring Rate Calculator V4.0
    By FireDog46 in forum Canadian Bikes
    Last Post: 02-29-2004, 11:28 AM
  5. Mountain Bike Gear Ratio Calculator V4.0
    Last Post: 02-29-2004, 11:27 AM
