downhill racing question- Mtbr.com
Results 1 to 10 of 10
    For Those About To Ride
    Reputation: shook_dh's Avatar
    Apr 2005
    do you usually shift gears during a race or just pick the best gear and ride with it?
    Reputation: CRASH's Avatar
    you will change gears at some point of a race. I never did a race in one gear
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Yes you will be shifting gears
    Glad to Be Alive
    all depends on the course, but most courses you will need to shift gears
    helpful hint for racing.....use your limiter to take out the first two gears (easiest)
    aka Jesse Palmer
    Reputation: jp3d's Avatar
    Quote Originally Posted by SHIVER ME TIMBERS
    why would you want to do that? Does is help with shifting through the others, or just keep you from shifting to granny and losing your chain into the spokes?
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    If you can pedal, you can shift... shift when nessesary*....
    * Definately did not spell that right
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    some people make the mistake of starting out in too high of a gear thinking they will end up in that gear. Get a fast start, then shift as needed. Depends on the course start though. You may have to shift up or down during turns or slight climbs.
    N* Bomber Crew
    Reputation: Raptordude's Avatar
    I can guarantee that you WILL shift during a race. Hell, the starting gate will require you to shift.....
    Northstar 2008 Riding Crew
    Glad to Be Alive
    Quote Originally Posted by jp3d
    usually you don't need the easiest gears, so it is better to elimate them
    hardly any racers use more than 1 chainring, and they all have chainguides, yes u need to shift to be in the optimum gear for accelration, ie change down before a slow corner so u can pedal out of it quick and then change up when u get more speed up.
