Downhill Induced Nausea- Mtbr.com
Results 1 to 14 of 14
    Reputation: Mountainbikextremist's Avatar
    Jan 2005
    Bonking ... not feelin' well Downhill Induced Nausea
    When I am timing myself on a DH run "which I may add is not very long" and about half way through, I get very nauscious. To the point where i either throw-up, or get very close. This is very puzzling on my part, because I can do very sustained and technical climbs and NEVER feel this. It is only when I am pushing myself on the downhills and also note that i still get this even if i am or am not running on an empty stomach. I am in very good shape right now so that is not the problem. Let me know if you have any tips or ideas. These are my 3 possible explanations:
    1. I have develped muscles for endurace, not for sprinting.
    2. Just the fact that I am timing myself and have set a time i need to beat causes "anxiety" for lack of a better term?
    3. I am not breathing right "holding my breath?" I havent really payed attention to how I breathe on the descents.
    If I want your opinion, I will give give it to you...
    You got like 3 feet of air that time... -Napoleon Dynamite
    [email protected] NYC Freerider
    Reputation: Master_Jako's Avatar
    might be a form of motion sickness? all the jitter not playing well on your body. might be somthing you ate/eating.
    Jan 2005
    Quote Originally Posted by Master_Jako
    That could very well be true. Maybe I'll look into motion sickness meds?
    Glad to Be Alive
    I would say you are holding your breath a little too long in the hard spots.....
    try
    breathing in and out like a freight train on your next ride
    also work faster up the mountains to build more endurance
    Jan 2005
    Quote Originally Posted by SHIVER ME TIMBERS
    try
    Im going riding tomarrow morning, and i will put both these tips into practace. I'll repost on results. Thanks for the help!
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Maybe a rapid change in altitude is something your body doesn't like. That would explain why it does it on the descents but not when climbing. You're going down much faster than you're going up. Just a thought.
    moaaar shimz
    Reputation: tacubaya's Avatar
    Quote Originally Posted by snaky69
    That has logic to me, just depends how much you decend.
    Jan 2005
    Im not making that dramatic of a changed in altitude. But in the mountains and ski resorts i could see some logic in that though.
    moaaar shimz
    Hm then go to a doctor...
    long standing member
    Reputation: PCinSC's Avatar
    Quote Originally Posted by Mountainbikextremist
    Says you. Seriously, though, are you extremely out of breath when this happens? Is your heart rate highly elevated?
    I may, depending on how you answer the above questions.
    Patrick
    1. I have develped muscles for endurace, not for sprinting..
    That's your answer. You're not use to going anerobic. Do multiple hill climbs as fast till you want to puke. Or do multiple flat land sprints (intervals) till you want to puke. Oh yeah this type of training should make you faster because you can go anerobic for a longer time.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    i get the same feeling from a local jump line that is about 20 jumps long (only spanning a few hundred yards, not an entire hillside). when i get to the end i very regularly get the dry heaves, not sure what gives...
    i used to race bikes for suzuki, threw up after EVERY race. 122 races, vomit. motion sickness at its best. i tried dramamine but it made me drowsy so, no go with that. i dont get it on downhill run, but dirt jumping always makes me a bit dizzy, i never eat beforehand. keep us posted if you figure something out.
    Equal opportunity meanie
    Reputation: DHidiot's Avatar
    It is you shocking your muscles that are not accustomed to that sort of activity (fast twitch reactions - high intensity). It is also amplified by you holding your breath. Example: hold your breath for 60 seconds while doing clapper pushups as fast as you can - same thing will happen (I do not recommend you actually do this unless you're really damned bored, but you can certainely imagine the effects). Keep doing really rough DH runs. Make your muscles feel that lactic acid pump from hard hits, not endurance.
    This is one I learned from watching Duncan Riffle race. You can hear him over his bike when he's pinning it. The sound you hear is his breathing rythym (sp?) he keeps a constant cadace through his runs - I think. He may alter it before technical sections or sprint sections, but you get the idea. Some sort of breathing regulation is definetely necessary for sprints.
    If you're comfortable on the bike and riding within your limits anxiety isn't an issue since you're probably used to the adrenaline rush associated with a fast DH run.
