Dot Fluid on tyres- Mtbr.com
    Rider of the Faith
    Reputation: Musashi's Avatar
    Dot Fluid on tyres
    I was doing a bleed and yep... you guessed it... The nozzle came out and I got Dot fluid all over my tyre. I wiped it off with alcohol and water but I can still see some between the rim and rubber. Should I be worried?
    moaaar shimz
    Reputation: tacubaya's Avatar
    Just hose it down real good (water deactivates DOT fluid).
    Glad to Be Alive
    i wouldn't worry....I would be worried about my brake pads and rotors though
    I can ride a two-wheeler
    Reputation: thomasmunka63@hotmail.com's Avatar
    are you serious?!
    Dot Fluid causes tires to completely explode causing world disaster
    ....but I would most def check out if there's even a drop of fluid on the rotor and/or pads; could mess them up for a while until it gets ridden out
