Does anyone on this board run a 10mm bolt on rear axle on their azonic outlaws....- Mtbr.com
Results 1 to 11 of 11
    Say Car Ramrod!!
    with 135mm rear spacing? i keep having to tighten my rear hub and its effin annoying...
    I wish my grass was emo so it would cut itself...
    I hate texas
    Reputation: Chicodude01's Avatar
    Sep 2004
    Wait wait wait......How do you hook this up?
    I have outlaws, but since weyless is discontinued, I cant get the 12mm through axel drop outs. I would love a 10.mm setup, cause then i could rock a bolt on...
    Respect Cape Cult Member #21 "The California Respector"
    Say Car Ramrod!!
    Quote Originally Posted by Chicodude01
    all i want it a regular 10mm bolt on rear axle but am not sure if they make such a beast for this wheelset
    I hate texas
    Sep 2004
    I don't think they do, But I have been considering grinding my drop outs down 2 mm so the 12 MM axel will fit. But with the weyless dropouts, they are removable and made outta hella think aluminum
    Say Car Ramrod!!
    still waitin for someone that knows, i thot i saw that someone had a set up like that
    edit: i think my axle may be bent because when it is loose i can rotate the tire a half rotation and it will be tight. so a new qr rear set up may be in order...
    I am running them that way.You need to make the QR to12 mm convesion then get a 12mm axle with a 10mm STEPDOWN. You can get them from Azonic directly works great, though Azonic is a bit slow on the shipping.
    Going downhill? Get AMBPed!!!
    Another festivus MIRACLE!
    Reputation: bullit71's Avatar
    exactly
    just go to azonic's website, or do google search. get the 12mm axle w/10mm stepdown. I did this to my bullit with the azonic outlaws. works like a charm! easy installl too.
    Say Car Ramrod!!
    Quote Originally Posted by bullit71
    did u just use the existing bearings and everything? or was there extra parts that they sent you with the new axle?
    I hate texas
    Sep 2004
    Don't skid
    Reputation: KONA_in_SB's Avatar
    I am running the 10mm bolt on and like the others said, just set it up for the 12mm thru-axle and then order the 12-10mm step-down axle from Azonic. There is no bearings to change. All the hardware except the step-down axle should have came with your wheels.
    Still on Training Wheels!
    Reputation: drum714's Avatar
    Quote Originally Posted by KONA_in_SB
    Thats it exactly. I'm running the stepdown thru axel on my Coiler and its Deffinetly worth the money. Heres the link through Azonic.
    http://www.azonicusa.com/catalog/pro...roducts_id=116
    It's not a good ride if you don't scare yourself at least once.
    Yeah...I'm Sponsored..................by my Bank Account
