Do single ply tires have a place?- Mtbr.com
Results 1 to 49 of 49
    Reputation: creyc's Avatar
    May 2005
    I was riding some new trail in so cal today, and botching most of it since it was all new to me and I managed to pop my rear tire. I'm pretty sure I knew exactly when it happened, which was on a very small rocky edge I came down on and heard a pop/snap sound like when you kick a rock in your tire. I was running 45 psi.
    Sure enough, a minute later I was down in the first turn.
    I'm running 2.35 minion DHF/DHR which are single ply tires, with normal inner tubes. My LBS convinced me to go this route based on the fact that I do some light climbing, and the single ply 2.35's are way lighter. Sure they're lighter, but can they actually hold up for light DH use? I'm 175lbs and ride a Foes Fly. I need more traction but I'm afraid to drop pressure for fear of MORE flats.
    Bike Ninja |||
    Reputation: chooofoojoo's Avatar
    Feb 2007
    They are great for XC... not so much for DH or FR. Even further, i'd question them on a serious AM bike. My favorite was to go is to run UST tires. even if your are still running tubes. thick sidewall, but not as stiff as the DH casing ones. They are about as heavy as the DH casing ones if I remember correctly.
    get yourself some Specialized Pin'it 2.5 umma gummys.. never look back (btw I ran them on my foes when I had it.)
    Proud to represent Mojo Wheels.
    Look at the time!
    Reputation: lelebebbel's Avatar
    Jan 2005
    sure they do. It all depends on what kind of trails you ride. On most trails out here in the PNW there are hardly any rocks - i could easily get away with single ply front and rear.
    Since I'm too lazy to change tires for the occasional rockgarden DH trail, I ride single ply front, dual ply rear (both minion 2.5" - had to buy the front tire in germany, since maxxis doesn't sell 2.5 inch single ply tires in the US for some reason).
    Haven't had a flat with that setup since 06.
    wanted: Cannondale Lefty w/ V-brake studs
    Bike Ninja |||
    Feb 2007
    Quote Originally Posted by lelebebbel
    I hope you knocked on wood
    agreed on that set up. a lot of people do that out here in rocky Colorado as well.
    EastBaySteez
    Reputation: Freerydejunky's Avatar
    I rode a timberwolf at north star all season. Did not pinch or flat that baby once.
    But then again Im 120 with gear. Being skinny rocks.
    If your not heavy you can ride um.
    Gamut
    Team Evil
    Formerly: motormonkeyr6
    May 2005
    I can't help but wonder if its something I'm doing wrong, because I didn't even have much speed when it happened.
    Obviously I'm not about to drop 60lbs so I can ride without flats, so what is my best bet for riding the rocky california stuff and still staying light?
    The problem is the stuff is just so loose you almost have to run a 2.7 front at least, I wasn't hooking up at all with my skinny tires.
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    i would just go with some dual ply tires. They are heavier, but you won't get any flats. thats for sure.
    HARDTAIL PRIDE- 09 Kona Five-0
    EastBaySteez
    I run a 2.7 Minion up or a 2.5 Kenda Nevegal in the front.
    and a 2.5 Mobster in da back.
    No problems in the cali rocks
    Gamut
    Team Evil
    moaaar shimz
    Reputation: tacubaya's Avatar
    I rock dual back, single front
    Bike Ninja |||
    Feb 2007
    if you want bigger and more bad a$$ tires, i've said it before and i'll say it again. Specialized Pin'it 2.5 umma gummy tires. Ran tubelss. say goodbye to pinch flats, and say hello to ungodly traction, that outlasts minons substantially.
    moaaar shimz
    Maxxis > All
    Quote Originally Posted by creyc
    If you want dual ply tires i could sell you a set of brand new minions that I have lying around, they're 3c and 2.7 front 2.5 rear.
    Glad to Be Alive
    yeah 1 ply...but at 45 pounds I think it was just the one in a thousand shot....keep riding them....if you continue to have problems (I don't think likely) then switch
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    DH tubes.
    Formotion Products
    http://www.formot
    EastBaySteez
    Quote Originally Posted by dogonfr
    DH tubes.
    Road tubes at 100PSI
    Gamut
    Team Evil
    May 2005
    Do DH tubes do anything but weigh you down and prevent every 9th thorn from puncturing? Seems like marketing...
    Jan 2005
    Quote Originally Posted by motormonkeyr6
    Sniffer
    Formotion Products
    http://www.formot
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Single's are OK on the front, no luck with them on back though. I run the same setup as tacabuya, single front and dual rear but my rear is a tubeless version. That keeps the weight reasonable and minimizes pinchflats. I weigh approx. 185 and am able to run 35-40 lbs. in back no problem.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    have you ever compared a DH tube to a std tube...?
    64,999,987 firearms owners killed no one yesterday.
    Quote Originally Posted by jamesdc
    how much
    squish is good
    Reputation: Clutchman83's Avatar
    I've got seperate wheelsets for XC and DH and run both tubeless. The XC set has single ply 2.35 Kenda Nevegals, never pinch flat anymore. When I was running tubes I was using 1.9-2.2 width tubes and it would pinch flat regularly unless I ran them at around 45 psi. At 45 they were bulletproof though, yeah, sounds like a fluke to me.
    DH tubes are alot thicker, I ran them for a while and they never pinch flatted, even when running at 20 psi or lower. They are really really heavy though!
    Glad to Be Alive
    they are a lot thicker
    Quote Originally Posted by matt
    how much
    what do you think is a fair price?
    Glad to Be Alive
    15 bucks each
    moaaar shimz
    At 15 bucks each send them to me
    they keep you from getting pinch flatted as easily since the tube is thicker than standard. this is good for places with rockgardens, or as we say in the good old USA, "rock shacks." like, "imma shred through this rock shack right quick little chillun baby."
    Reputation: wormvine's Avatar
    Funny, I seem to have the worst luck with the heavier DH tubes.
    I have been using specialized AM tubes with good results. I run a Panaracer Fire FR singleply on the rear and it holds up well and flats rarely at 40psi. I have been running doubly ply Maxxis Mobster 2.7's on the front but just cause they were cheap and sticky.
    I met a guy on the trail who had a a big slash on his rear tire running tubeless with slime of some kind. He didn't have a spare tube and he only had a compressed air cartridge which promptly ran out because the tire wouldn't seal. I only had a schrader tube and his rim could only use a presta tube. He was SOL and had to walk his bike a long way back to the trailhead.
    So always carry a spare tube and a hand pump when running tubeless!
    MTBiker
    I have popped so many single ply rears even with DH tubes. I recently went to DHR 2.5 rear and DHF 2.7 front, with DH tubes and they will never pop
    We can bomb the world to pieces, but we can't bomb it into peace -Michael Franti
    -C-
    -C- is offline
    Quote Originally Posted by SJensen
    Yes, a DH tube weighs as much as a house, and a decent XC tube weighs about 150g.
    Reputation: Quarashi's Avatar
    I've been trying to find a way out of this compromise as well since the trails that have gnarly downhills that are likely to knock your tires up a bit are the ones that have huge climbs at the start.
    Is complete UST the answer?
    I was thinking of a bombproof wheelset that would still be quite light (including tires). Thought about Mavic 819's or Stans Flows infront with 823's in the back on Hopes and go all tubeless. 2.5 front and 2.3 rear. The only tubeless tires that I can think of that are proven the michelins which are expensive and hard to get here and the Maxxis minion UST's which are also expensive and weigh a ton!
    About buying a bike:
    Quote Originally Posted by No MSG
    It's like finding a wife. Personality is important, but you gotta look at that face every morning.
    Double Post!
    Im a Cowboy
    Reputation: CrustyOne's Avatar
    Oct 2007
    Single ply high rollers here...pinched em every ride for 2 weeks...fitted maxxis DH tubes...no problems since, I am lightweight hard rider..there are rocks in my rides
    DON'T TELL ME I'M STILL ON THAT FECKIN' ISLAND! ....
    -C-
    -C- is offline
    Mavic 823 is pretty tough, not the lightest, but not as heavy as some suggest with the eyelets. I've run 823's for a while now & they are still good & straight.
    I'm toying with going for 819's, they are circa 510g with the eyelets (weighed them up myself) so offer a good weight saving over the 823. I'm pretty smooth so they should hold up well.
    You may struggle with a 2.5 on an 819 rim, its way too wide. 2.35" is alright though.
    Interesting about the Michelins - you are aware that DH16 2.2"s are nearly 200g's heavier than a 2.35" Maxxis UST? They don't seat anywhere near as well as Maxxis either.
    sixsixtysix
    Guest
    I run single ply Maxxis Minions on my AM bike out here in the sharp rocks of Arizona with basically no problems other than the occasional burping. I run them converted to tubeless using Stans, so even if they do puncture or tear, they seal back up right away.
    I gave up on tubes on all my bikes last year, they are just a pain in the a$$ with all the rocks, at 1 point I had 10 flats in 1 week. Since going tubless I have had 1 flat in a year on a total of 4 bikes.
    Err
    Err is offline
    Calm like a bomb
    Reputation: Err's Avatar
    Mar 2005
    I've been having good luck running single ply Maxxis ADvantages in 2.4 setup tubeless. I've torn one sidewall in a freak incident but otherwise they have been fine. The 60a durometer is a nice balance between traction and rolling/wear resistance. It's pretty darn rocky here in UT so tires tear up fast when they're not up to the job. Where I was blowing out Kendas constantly, the ADvantages are serving me well for days of long climbs mixed with DH style descents.
    Reputation: konut's Avatar
    Mar 2006
    Err sweet intense by the way.
    how tall are the advantage compared to minion 3c,i did try a minion 2.35 but just to narrow and skitery and the 3c just to heavy,i do know that the 3c minion is taller than my buds high roller.
    i did have maxxis dh tubes but just so heavy so i have put maxxis freeride tubes in and 40 psi which is helping the rolling resistance just the tyres are killing me on the ups.
    Jan 2005
    WTB Dissent rolls fast & hook up.
    Formotion Products
    http://www.formot
    Mar 2006
    dogonfr,are they a lot better than timberwolfs i tried them to but the tall skinny side lugs folded under my weight at speed and made me wash out on every corner.
    Jan 2005
    Quote Originally Posted by konut
    Better than the TimberWolf is a tough call because other than the weight the T-Wolf is awesome. The Dissent is 2nd by a tad, im using the Kevlar with DH tubes at 24-26psi depending on conditions. Never had a problem with them folding under my 185lb weight. I also tried the Prowler & that tire slid all over the place in the loose like being on marbles but was decent in the moist giving a little slide then hook up.
    Formotion Products
    http://www.formot
    EastBaySteez
    I ran a Timberwolf at Pacifica today regular tube at alittle over 30psi in the back, no pinchflats .
    Im the deffinition of a Hack. I find a line, Point and shoot on a 7" Freeride bike
    Example: Look at that knee If you go frame by frame you can see that im on the VERY top of the burm.... draging the brake so I dont slam into the tree
    (sorry for the obscenity)
    <embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="https://i5.photobucket.com/player.swf?file=https://vid5.photobucket.com/albums/y158/132132/100_0759.flv"></embed>
    Gamut
    Team Evil
    Look at the time!
    Jan 2005
    Advantage 2.4" are the same size as minion 2.5". If anything, they are slightly bigger.
    Jan 2005
    <embed type="application/x-shockwave-flash" wmode="transparent" src="https://i5.photobucket.com/player.swf?file=https://vid5.photobucket.com/albums/y158/132132/100_0759.flv" height="361" width="448">
    T-Wolves are front tires not very good on the rear.
    Formotion Products
    http://www.formot
    EastBaySteez
    Everytime I put one up front it washes constantly, sucks in the wet balls in mud.
    In the back it just sounds like a tank tread!
    Well I went back to the old set up Minion up front 9o9 FRO in the rear
    Gamut
    Team Evil
    Mar 2006
    motormonkeyr6 thats what i found with the timberwolf aswell,but i am 210 so dont help i guess.
    lelebebbel thanks will have a look at them.
    oh and that vid aint working for me.
    I weigh 215 & run single ply tires with Kenda medium duty 1.2mil thick tubes. Run my 2.4 / 2.25 tires @ 32-40 psi on a minimum 28mm rim. Run a standard tube (less than .9mil), rim less than 28mm or pressure below 30 and it's pinch flat city. For DH I run DH tubes 2.0mil with 2 ply tires - ran single ply tires & DH tubes but it is hit n' miss for pinch flatting.
    Slow Patrol
    [QUOTE=konut]
    QUOTE]
    Can't compare to Minions but the ADvantage is as tall as the Intense 2.5 DH tires I had once.
    Mar 2006
    normanpcn do you have advantage and how do you find it.
    More Riding Less Internet
    Reputation: thom9719's Avatar
    Jan 2005
    I run dual ply on the DH bike. 2.5 Minion DHF front and rear.
    I run 2.35 single ply mobsters on the slopestyle/slalom bike.
    Kyle,
    Slow Patrol
    I think it brakes and climbs well and corners very well. I am timid and these things gave confidence. My bike came with OEM ADvantage which have a wire bead and I wonder if they have the 60a rubber or a harder OEM rubber like 70a. I only question this since I got a new one to replace one which I cut.
    The sidewalls are thin but this is a known factor going in. My current heavy DH tire favorite is the Specialied Pinn'it. I live in dry, dusty, rocky, hard pack SoCal where the "hard pack" is so hard it is really more like light tan asphault. The ADvantage is my current fav for AM lighter weight setup.
