Do Different Brakes Need Different Mounts?- Mtbr.com
Results 1 to 6 of 6
    Moose Member
    Reputation: Moosey's Avatar
    May 2010
    Oh poo. This is probably common knowledge, but do different brands of brakes need different mounts?
    i just tried mounting my new avid elixir brake on a hayes mount, and it don't work... is something wrong or is it just a new mount i need?
    is there a place down in mammoth to buy avid elixir mounts? im headed down tonight.
    with Avid calipers, you need to use their "cps" washer system or it wont fit. when you use these washers, your Hayes mount will work.
    Moose Member
    May 2010
    can i just throw some washers on there? or will it blow up if i dont use theirs?
    thanks for the info...
    Quote Originally Posted by Moosey View Post
    yes, you can but finding washers big enough might be tricky. their "CPS" washer system mainly helps to align the caliper on the rotor....but even that doesnt work 100%
    if you bought your brakes new, they should be in the box
    Moose Member
    May 2010
    Ok that makessense. I got the brakes with a used bike, so I just replaced the cable and am trying to mount them before I bleed them. I live in Fallon where everything is janky... ill make something work.
    Reputation: MidNight_Rider's Avatar
    Mar 2011
    When I first read your post I thought you were talking about the difference between IS and Post Mount. Those CPS washers are pretty sweet when you need to shim calipers.
    -Chris.
  1. Any lightweight brakes with IS mounts?
    By Mr. IROC-Z in forum Brake Time
    Last Post: 02-25-2011, 02:28 PM
  2. Marzocchi and Manitou brakes mounts?
    By fiveo in forum Shocks and Suspension
    Last Post: 08-04-2008, 11:36 AM
  3. Juicy brakes with Shimano mounts/rotors?
    By dav1d in forum Brake Time
    Last Post: 06-13-2007, 12:09 PM
  4. What type of adaptor? (Post brakes with IS mounts)
    By morenowalh01 in forum Brake Time
    Last Post: 06-02-2006, 11:36 AM
  5. Will v-brakes fit on old canti mounts?
    By Warthog in forum Brake Time
    Last Post: 07-08-2004, 01:55 PM
