Do chain guides help chain jump- Mtbr.com
Results 1 to 5 of 5
    Have a Kona Stinky and the chain is jumping between chain rings when landing off of drop-offs. Will a chain guide like the E-13 help? Would like to still keep 2 chain rings. Also what causes discs to get out of tru?
    a dual ring chainguide will only help on the back pedal, they wont keep the top of the chain from dropping. Its possible your front derailler needs some adjusting, but really its not possible to completly bulletproof a 2 ring setup, at least until someone creates an upper-guide system.
    That's funny, since I installed my Dewlie chainguide I haven't dropped a chain in 2 seasons of riding. Before that it used to drop to the granny when landing drops or ripping through rough sections.
    That's backazzward
    Quote Originally Posted by zedro
    Actually the only time a dual ring fails is while backpedaling. I ran the Dewlie for all last season, including over 100 runs at Whistler, and never ever had the chain skip or shift while coasting or pedaling forward, but it did shift to the small gear several times when I pushed the bike backward.
    I had that when I first installed it too. I swapped the roller around so the step is on the inside, haven't dropped a chain since. The step doesn't allow the chain to drop. I think there's another manufacturer that actually uses a step roller for their dual ring chainguides. That's where I got the idea from. Try it out, see if it works for you too.
  1. Disco chain guides
    By Wily in forum Singlespeed
    Last Post: 09-28-2004, 06:02 PM
  2. > 1/8" chain stretch - time to replace the chain rings?
    By journey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2004, 05:05 PM
  3. 9spd chain on an ACS Claws freewheel... good idea?
    By jean-seb in forum Singlespeed
    Last Post: 03-01-2004, 07:40 AM
  4. livid chain guides
    By tuggy in forum Downhill - Freeride
    Last Post: 02-21-2004, 08:02 PM
  5. Best way to keep a chain clean?
    By gottjr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-19-2004, 07:04 PM
