DMR 20mm thru-axle rigid forks?- Mtbr.com
Results 1 to 6 of 6
    DMR sells a 20mm thru-axle rigid fork. Anyone know about these?
    Looks like an awesome upgrade to my Rigid Trail bike. This suckers gotta be STIFF!
    https://www.dmrbikes.com/?Section=pr...s&itemid=FRK20
    SamIAm
    Reputation: SamL3227's Avatar
    it is, i have the 12mm version. its made more for street riding tho, it has a much shorter AtoC length, so u would have to check to see if that would throw of ur geometry much, but other then that it will work fine.
    <(*-*<) Go Ride (>*-*)>
    Yeah, I'd worry about screwing with geo also. If it does, the Funn Stiffy is available in both 100mm suspension corrected or 130-140mm corrected versions
    Dec 2005
    this fork should correct for some suspension as well. DMR told me it has an AC measure of 440mm.
    Jun 2005
    Dec 2005
    Quote Originally Posted by dkelley383
    yeah i don't know why discrepancy. i will double check before i buy.
    here is email from DMR:
    Hi Brian
    440mm
    All the best
    Rich
    Upgrade Bike Design | Distribution
    DMR Bikes, Kinesis, Oval, Geax, Tektro, Kriega and more
    Tel: +44 (0) 1403 711 611 Fax: +44 (0) 1403 710 753 Direct Tel: +44 (0) 1403 712 548
    Technical@DMRBikes.com Rich@Upgradebikes.co.uk Tektro@Upgradebikes.co.uk
    ----- Original Message ----- From: "brian xxxxxx" <xxxxxxxxxx@hotmail.com>
    To: <Technical@dmrbikes.com>; <info@dmrbikes.com>
    Sent: Wednesday, April 11, 2007 3:42 AM
    Subject: Trailblade2 20mm Through Axle Fork
    hello,
    i was wondering what the Axle to Crown measure and weight of this fork are?
    thanks for your time!,
    Brian
