Disc Brakes Shifting- Mtbr.com
Results 1 to 2 of 2
    Hey i have a problem i can hold my front brakes and my front disc slides back and forth i pulled the wheel off and the disc was loose so i tighted it up then rode it around the noticed it was loose again what should i do ? also it is bend slighty could this have sumthin to do with it
    Reputation: The Rose's Avatar
    Use blue loc-tite on the threads of the disc mounting bolts. if the bend in the disc is slight, you can try to align it with a couple small adjustable wrenches or with disc aligning tools.
    Last of The Allaire Bastards
