Diamondback response comp freeride downhill dj fork help- Mtbr.com
Results 1 to 29 of 29
    Reputation: dervishboy05's Avatar
    what fork could i run with lots of travle and is relitivly cheap. lets say under 320
    freeride jerk
    Reputation: Tj Pope's Avatar
    your bike will sit like a dirt bike, because of the headtube being so high, and the angle youll be at. and the haedtube will eventually crack or even snap do to the stress from the fork.
    i dont think your supposed to exceed 150mm or somehting like that on those.
    but if your getting a new frame and dont care about the response than i say whatever.
    SHANTY
    Quote Originally Posted by Tj Pope
    by sitting like a dirt bike how much higher are we talking from the axle to the frist crown do you know the length or do you know how i can finde the length
    i just cant picture the headtube cracking or snaping off ... if you could please explain how so much stress is put on the headtube of the bike.
    150 actuly 120 voids the worenty sense it comes with 120 and diamondback recomeds that i do not excede (but they have to say that) i do care about the respose i paid alot of money for it and i dont want to ruin it if i can avoid it
    if you think that 150 is the maximum travle i can go with than what do you recomend?
    thank you very much for your post
    Aug 2005
    Do not do it. Wait until you get a new frame.
    Sep 2004
    I think the fork you're looking at costs more than your bike did. Not all bikes are created equal, and that rings true especially with machined tubing and welding techniques. The response was designed to be a shorter travel bike, which means the headtube was not reinforced enough to cope with the high stress that a dual crown or long travel fork exerts on it. I wouldn't do it, because the force put on the headtube by the dual crown fork will tear the headtube apart.
    I rock out like Bon Jovi in some 80's jeans
    Meh.
    Reputation: XSL_WiLL's Avatar
    That's a Jamis Komodo that cracked with a SC fork on it. The Response is not as strong and the DC will put loads more stress on the headttube. It's very easy for a headtube to sheer off. Look up some pictures of ECH's p.bike and Soul Cycles. Both had the head tube rip right off.
    Meh.
    The fork will also way slack out the angles. Steering will be sluggish, the front end will sit super high. The bottom bracket height will get jacked up. Center of gravity is higher. Standover height increases.
    Meh.
    First one is a p.3
    Second bike is a Soul Cycles
    Third is a Devinci
    First one is a p.3
    Third is a Devinci
    Thats why you dont run 8 inch travel dual crowns on dj hardtails.
    Meh.
    Actually, I'm pretty sure he knocked the DH-3 down to 6 inch, and the Devinci was a full susser. The Titan is more FR than DJ. I've seen another Titan end up like that with a Sherman Flick on the front end.
    If those frames ended in such a manner, it's pretty clear what an aggressive XC frame with a Super T will end up like.
    dubble post
    lol
    whell i have nerrowed my search down to 3 forks all under 150mm all single crown
    but i still need help decieding what would be best for me
    im not going to do anything over 6 foot drops jumping will be kept to a miniumum lots of faced paced downhill freerideing along with trail riding up hill and down hill
    option one.
    marzocchi drop off 3 $268
    rebound adj
    air preload adj
    130mm travle
    20mm axel
    option two.
    marzocchi all mountain 3 $207
    tst 2 adj ?????
    coil air combo
    140mm travle
    drop out axle
    option three.
    Marzocchi Z1 Sport RV $300
    air preload
    rv rebound adj
    150mm travle
    20mm axle
    what one should i get do you know anything bad about any of these modles?
    i dont have enough cash for the sport rv nore the drop offs because of the tax + the new hub i would have to get... so it would take me longer to get those where i could probubly get the all moutain for by the end of the week
    edit: i paid 640 for the bike
    J'aime le Dunkeld
    Reputation: kenneththecurtain's Avatar
    They all have pretty cheesy damping, I think (but may be wrong) that rv means the same damping as drop-off. Which leaves the all mountain. A chum of mine has that exact fork and he seems to like it.
    attending to my vices
    Reputation: moshelove's Avatar
    Jun 2005
    rock shox tora??
    OVER THE LINE SMOKEY!
    Meh.
    Yeah, RV damping is the lower-end side of things. It'll spike over the fast stuttery stuff. There are options other than Marzocchi...
    Second the Rockshox Tora or Revelation.
    TPC or TPC+ Manitou Sherman would also be a good option.
    That bike is not a DH bike, start saving for a new frame.
    tora has bad reveiws everything els cost to much ... i cant be supper picky cause i cant aford spectacular stuff
    go chase the sunset
    Reputation: Ardent's Avatar
    My vote'd be Tora.
    Quote Originally Posted by Ardent
    My vote'd be Tora.
    why... it has such s__ty reviews
    I rode a tuned Recon that was awesome. Maybe you could try to find one used. Oh, and btw, unless your hub is convertible to a 20mm, you're going to have to get a new one and your wheels relaced if you get a fork with a thru-axle. Just wanted to make sure you knew.
    Meh.
    Quote Originally Posted by dervishboy05
    Reviews aren't everything. People are more inclined to write a review when they have complaints rather than praise. The MoCo damping in the Tora is the same damping in the Pike and Reba. MoCo is where it's at.
    true .... but what modle or tora are they refering to i realize that there is more than one tora and witch tora has the moco dampning... also i hear alot about this blow out problem with the air chambers or somthing.. is this comom?
    wow why does this drop off 3 have drop outs?
    http://cgi.ebay.com/MARZOCCHI-DROP-O...QQcmdZViewItem
    Meh.
    All forks (sans broken ones) have dropouts.
    ... what?
    sans? (is that a brand or sombody) all forks? (are you sure?)
    Meh.
    Do you even know what a dropout is? Even frames have dropouts. Dropouts are what the axles fit in, regardless of size.
    yes but i dont see dc 888s with drop outs... he said all forks have drop outs i was thinking a drop out was only for the kind that clamp i thought a true axle was not called a drop out.... am i wrong?
    Meh.
    Yes. You are wrong.
