DHX spring questions- Mtbr.com
Results 1 to 13 of 13
    Reputation: po0ptruck's Avatar
    I was looking at a the shock i recently got, Fox DHX 3.0 and i saw the spring was 450lb, which i thought was kinda heavy for me (i weight 165 with gear and dont do anything too big). the original spring i had on my bike (iron horse 7point3) has a scratch right over the number, it looks like 350, it was the original spring, but for a 5th element shock. the dhx spring is 5.5in long x 2.8in stroke, the 5th element one is 6 3/8 long x 2.75in stroke (i think) i can make the 5th spring fit into the fox shock by adjusting the large nut on the body. i think the 5th element is like .25in bigger in diameter too but idk if that would matter.
    am i doing anything that could hurt the shock/my bike/me? i am doing it for a smoother ride cuz i do mostly downhilling and almost never bottom the DHX now, even at a very low psi.
    thanks for the help
    god built south dakota saying "i dont want anybody to ride MTB here, im going to make it suck ass." so it sucks ass Luke 4:2
    Reputation: GnaR9's Avatar
    Quote Originally Posted by po0ptruck
    thanks for the help
    DHX's have a really tight tolerance for a springs outer diameter. I would just buy a Fox spring w/ the proper length and weight. They're around $30, so it's one of the cheaper things you can buy for your bike.
    i slide the 5th spring onto the DHX body and it fits fine, its only like .125" closer to the piggyback than the regular one.
    I'll trade you a 350 for your 450...its a stock Fox spring.
    That's uncompressed. It may rub a bit into the travel. Go for it though, it might work. I'd just dish out the $30 for the proper spring though.
    i'd like to use this one if i can, cuz it is a huge bucking fitch to get that shock out and i want to ride it. ill definatly keep that in mind if this won't work out.
    Ugh, I don't understand why people are so lazy w/ their $1,000+ rigs. W/ the current Fox spring are you getting the right amount of sag? You could throw the progressive on there if not and jump up and down on the pedals for a bit in your front yard to see if it rubs the piggy back. If it doesn't go for a ride and check after a the first run. No rub? You're golden. If it rubs, get the right Fox spring.
    Now that I think about it you should be fine w/ the progressive. Ti springs have a bigger OD and most weights don't rub until you get into the 500lbs range.
    i put the 5th spring on the 5th shock, and its really really close to the piggyback, on the DHX shock its about twice the distance away. im definatly going to bounce around in the yard before i even think about hitting the trails.
    it took me about 2 hours to get the shock out, mainly cuz the shock mount has play in it and it gets all marred up. nothing i can do about that tho, even the sunday shock mounts have play in them.
    Reputation: Hardtails Are Better's Avatar
    May 2005
    The DHXs tend to rub on the BO knob, and since you've got a 3, it lacks that knob and probably won't rub.
    thats good, ill probably have to lessen the rebound dampening but what about the psi? i keep it at like 85-90 usually will it have to go up down or same?
    May 2005
    You might want to up the boost pressure a bit. Experiment.
    ya i thought so, it should be a softer ride tho, although it can't really get that much smoother that DHX is soo much better than the 5th element, that thing was crap.
    Glad to Be Alive
    450 is what they told me to use with my 210 pound body...I needed a 550 though
    ride it and feel it out first
