DHX 5.0 or 4.0??- Mtbr.com
Results 1 to 15 of 15
    Jun 2005
    DHX 5.0 or 4.0??
    Hey, I race downhill and was wondering if the dhx 4.0 or 5.0 coil would be better for the money, I have heard bad things about the propedal that the 5.0 comes with, and was just wondering which shock i would get more performance out of. Thanks
    moaaar shimz
    Reputation: tacubaya's Avatar
    Get the 5.0, I've heard bad comments about the 4.0 as it lacks adjustments etc
    Glad to Be Alive
    Quote Originally Posted by motoxrider913
    for DH racing I actually turn the pro-pedal up a few turns...definately get the 5.0 or better yet get the Roco by Marzocchi....I am debating TST or World Cup right now
    Jun 2005
    yeah, i forgot about the roco, any word on that? what model of the roco and such?
    moaaar shimz
    TST if you need plataform (like propedal), WC if you just want pure plushness
    Big Test Icycles
    Reputation: Hangtime's Avatar
    I have both and except for the lack of bottom out adjustment on the 4 they are the same. If you need the bottom out adjustment then get the 5 but if not and can get a good deal on a 4, then go that way. I presonally have not had a problem with either, the 4 is on my Stinky D and the 5 is on a 5 Spot. The 4 gets hammered harder and has performed well. The 4 even weighs less if that matters to you.
    http://www.foxracingshox.com/fox_bicycle/bike_index.htm
    "Its All Good"
    Reputation: Whafe's Avatar
    Better still, check out the CCDB, the shizzle shock all round!!!!
    moaaar shimz
    Not everyone in here shiat money like you do Whafe
    Reputation: Hardtails Are Better's Avatar
    May 2005
    The 4.0 has the same Pro Pedal adjustment as the 5.0- it just lacks the bottom out adjuster. I've got a DHX 5 on my Bottle Rocket right now, with a Roco TST on the way. The DHX has been pretty good, but not great. I'll post up once I've got some time on the Roco.
    SMT, I don't think they make a Roco TST big enough for the M3.
    Reputation: konut's Avatar
    Mar 2006
    although usually a marzocchi fan,a pushed dhx4.0 will out perform a standard dhx 5.0.
    also peat and rennie run pushed dhx 3.0.
    if you go with a roco def go with the world cup and if you go with the dhx get the 5 ive ridden on both and both are good shocks.
    Aug 2005
    All DHX's are the same once they are PUSHED.
    May 2005
    Quote Originally Posted by konut
    Those probably started life as DHX 5s. Push takes off the bottom out adjuster, and the PP knob as well, I think, when they do their tuning.
    i would get a 5.0 over a 4.0. you can run a plusher feeling shock with a more progressive feel than a 4.0
    May 2005
    There's no good reason, other than maybe cost, to get a 4.0 over a 5.0. The 5 just adds a bottom out adjuster- other than that, they're the same thing.
