DHX 3.0 help- Mtbr.com
Results 1 to 6 of 6
Thread: DHX 3.0 help
    DHX 3.0 help
    my friend bought an 05 kona stinky. it came with a fox dhx 3.0. he weighs 145 and if he drops anything bigger than 3 ft it bottoms out. there is 150 lbs of air in the shock. weve tried turning the coil both ways and it hasnt really done much, please help. have a nice day
    Former Noob Herder
    Reputation: zedro's Avatar
    that model can be charged upto 200psi. If that doesnt work, then either Kona had the shocks compression/boost valve tuned wrong or there is something wrong with the damper.
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Quote Originally Posted by heggler9
    I had the same thing happen on a dhx 5.0. It would bottom out on everything, it sucked and I thought all other dhx owners with bottomless shocks were liars .
    Anyways I sent mine back to Fox and they said their was nothing wrong with it, yet still rebuilt it. I just got it back and have been testing it for 2 days. So far it works really well. It never bottoms out, pedals great, yet still is very plush.
    I don't know if the dhx 3 has a bottom out control on it. But if it does you can easily test it by taking the spring off and cycling the suspension with the bottomout control turned on each extreme. If you can't feel any difference then send it back.
    Former Noob Herder
    Quote Originally Posted by Alloy
    it doesnt, it only has the pressure adjustment, with the 70-200psi range. Unfortunatly it'll affect the whole compression range, unlike the uber-cooler DHX5.0.
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Zedro, is that number from their site?
    Quote Originally Posted by zedro
    I've been gone a few days (riding, Zedro, eat your heart out...LOL!), but isn't the info on their site wrong? It had that pressure listed on their site for my DHX 5.0 but the Fox tech said the pressure should only be 75-125 psi. I heard Jm, come up with this same info.
    Former Noob Herder
    Quote Originally Posted by TNC
    that number is from the tech manual. The difference is in the fact the 3.0 does not have a volume adjustment on the piggyback. I'm guessing the pressure limit for the 5.0 is based on setting a 125psi max limit with max volume, then when the volume is decreased via the boost valve adjuster, the pressure will increase to about 200psi.
  1. 2 ride DHX review
    By AK Chris in forum Turner
    Last Post: 09-23-2004, 11:41 AM
  2. DHX - first ride report
    By SSINGA in forum Ellsworth
    Last Post: 08-31-2004, 08:50 AM
  3. Why DHX for Spot..????
    By Turtle 1 in forum Turner
    Last Post: 08-28-2004, 08:11 PM
  4. 5er DHX 5.0 & RP3 2 Week Review
    By Paul J in forum Turner
    Last Post: 08-18-2004, 07:08 PM
  5. Hoe-wee Hay-oh Batman! Moment / DHX 5.0 final setup
    By Bob the Wheelbuilder in forum Ellsworth
    Last Post: 08-18-2004, 04:56 AM
