dh tires- Mtbr.com
Results 1 to 9 of 9
Thread: dh tires
    Dec 2004
    dh tires
    just bought a new dh wheelset and need to know what width tires I can run on them....28mm wide...wasn't sure of the range of tires I could possibly run....thanks...
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    28's can run most anything.
    Quote Originally Posted by willida
    Sure, 30's and bigger will spread the tire's footprint more effectively, but 28's aren't exactly XC rims. I've run a giant Mich 2.8DH on a 28 with no problems. Usually the bigger issue is how big a tire can your fork or seat stays allow when choosing a big DH tire.
    Dec 2004
    I'm not really looking to put the biggest tire I can on the rim...I'm still testing the dh waters in the blue ridge mountains...what would be the thinnest I can go up to the largest, just considering the rim, not the frame.....thanks again
    Who are the brain police?
    Reputation: Locoman's Avatar
    My D321's are 28mm and....
    My D321's are 28mm and run 2.5's w/ no problem. In the review section someone says they run 3.0s on them.
    Mavics website lists recommended pressure ranges for tires starting w/ 1.0 (and this is for the 28mm 321s). -But I can't imagine you wanna run something that skinny.
    W/o more info, I'm sure you're ok for anything 1.5 to 3.0 (depending on your fork and frame for the upper limit). This is just an educated guess. Goto the manufacs website for better info. If they don't post it, email 'em.
    The Who - Glittering Girl
    Ween - The Grobe
    Yellowman - Strong Me Strong
    all your base are belong to us
    VIA
    VIA is offline
    Reputation: VIA's Avatar
    [QUOTE=Locoman]My D321's are 28mm
    Please fill me with info... wich D321 is 28mm... cuz mine , like I tho all D321's, are 36mm.
    I think you might be right. My old XC rims were 28 and the 321 are wider if my shoddy memory is correct. I wasn't sure about the exact measurements of the 321s so I went to Mavic's website before I posted.
    If you surf to the tab specifically for the Mavic 321 you'll find the following....
    "28 mm wide Cross Mountain rim for disc brakes only"
    So if I goofed with the size its only because Mavic did too.
    Ween - The Grobe
    Glad to Be Alive
    run some 2.25 to 3.0 if you want.
    If you weigh under 190 I would run some 2.5's
    VIA
    VIA is offline
    Quote Originally Posted by SHIVER ME TIMBERS
    and if you're over 230lbs run some 3.7's
    Yes 'locoman' , D321 are 36mm .
    Quote Originally Posted by Locoman
    I think thats the XM321, I've got 2.5" intense tyres on those with no problems though.
  1. Tubes for DH tires...
    By algae in forum Wheels and Tires
    Last Post: 08-26-2004, 12:51 AM
  2. portable tire pump for dh tires?
    By klepto in forum Downhill - Freeride
    Last Post: 07-07-2004, 11:39 AM
  3. DH tires!
    By SamL3227 in forum Downhill - Freeride
    Last Post: 06-20-2004, 02:53 AM
  4. DH Friendly tires for Jekyll 1000 (Shiggy please read)
    By BigDigger in forum Wheels and Tires
    Last Post: 05-29-2004, 11:55 PM
  5. tires for a mud dh circuit
    By klito in forum Downhill - Freeride
    Last Post: 04-28-2004, 07:14 AM
