DH tire wear ?- Mtbr.com
Results 1 to 10 of 10
Thread: DH tire wear ?
    DH tire wear ?
    A local rider gave me a 2.7 Maxxis Minion 40 compound to see if it would fit in between my 02' Super T's arch - no problem. He said I could keep it as he was going to another set of tires. The height of the treads in fine but the inside of the outer treads has the look of tearing almost a 1/4 the way through. Even though the tread height hasn't worn will the tearing on the outer tread cause any lack of traction? Thanx
    Can't get right...
    Reputation: dannymonky's Avatar
    Quote Originally Posted by keen
    I think the 40 compound is the softest they make. Depending on terrain and amount of time ridden the knobs can come off in bunches. Ther r sticky but dont last too long. On cornering the loss of those knobs might limit traction.
    I watch the O.C. cause it makes me happy...
    If misery was money i'd be the richest man on the planet.
    Former Noob Herder
    Reputation: zedro's Avatar
    Quote Originally Posted by dannymonky
    no kidding....and did you even wonder why he was getting rid of them?
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Quote Originally Posted by zedro
    WOW that never crossed my mind ! I thought it might have been the fact he was just sponsered by Kenda , maybe he had mentioned he wanted to run a larger tire, also recall that he liked run his hands across those little spikies on brand new tires...
    crumb
    Reputation: saviorself's Avatar
    Dec 2004
    uh maybe you should have mentioned there was a reason in your 1st post instead of this weak ass comeback. I wouldnt ride the tires, just get new ones
    ETBW
    Magura
    Quote Originally Posted by saviorself
    Uh, didn't know I had to give a full detailed history on the reason the tires were given to me. Thought a simple description would suffice. Zedro rips insight - your assumption of a "comeback" statement is well off the mark.
    Glad to Be Alive
    sponsored by kenda and giving you a Maxxis....hmmm what Zedro said
    Apr 2005
    ride them till you make a hole in the tire or at least ride them once and if you wash out turning or riding sidecut then replace them. And before you replace them, find the steepest, wet, newly paved road and wind out your highest gear while leaning as far over the bars as you can and skid.
    Apr 2005
    Takw/agranofsalt
    Jan 2005
    To answer your question....YES, the tearing side knobs WILL cause a loss of traction. I speak from experience. I just replaced my front Maxis with the same problem. I love the soft compounds but you have to replace them when they start tearing knobs, not when they they are worn down to slicks like a normal tire.
  1. Replies: 24
    Last Post: 01-02-2010, 07:31 PM
  2. Tires at MEC
    By turbo ultrasport in forum Eastern Canada
    Last Post: 12-04-2004, 04:00 PM
  3. Blur rear tire choice thread from old boards
    By CraigH in forum Santa Cruz
    Last Post: 03-03-2004, 05:16 PM
  4. Advice with Stan no tubes sealent ?
    By Johny Rotten in forum Singlespeed
    Last Post: 02-13-2004, 03:39 PM
  5. Suggestions for WW FAQ section
    By Trevor! in forum Weight Weenies
    Last Post: 01-19-2004, 01:22 PM
