DH Tire Removal Issue- Mtbr.com
Results 1 to 8 of 8
    I have a full DH casing Highroller on my rear deemax wheel. I am running it tubeless with Stans in as sealant. Hadn't ridden the bike in several months and have a slow leak, so I am trying to take the tire off and replace the sealant. The tire has been sealed to the inside of the rim with the old sealant like glue and I can't get it off even with a metal tire lever. Any ideas? I was thinking about trying soap and water. Thanks for the help.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Maybe try a using set of large pliers/channel locks to compress the bead? Or just see if you can get the sealant in thru the valve stem (not much fun if you don't have a removable core...)
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Jackalope Hunter
    Reputation: jayjudy13's Avatar
    Dawn dish soap generously applied.
    "That which does not kill you makes you stronger"
    Chilling out
    Reputation: bear's Avatar
    why not just push sealant through the valve?
    or use a needle injector through the tire (don't like that method myself though..)?
    Reputation: Danke's Avatar
    Lay the wheel on the ground (pick a spot with some give like grass or the lawn), and walk around the tire like it was a tightrope. Be careful you do this carefully and get your weight on the bead vs the rim, spokes, or rotor. When one side is free flip the wheel over and repeat.
    Stray Bullet
    Reputation: Nagaredama's Avatar
    If you're running the Mavic UST valve stems I would remove the core and inject the sealant through there.
    Reputation: Amazing Larry104's Avatar
    Aug 2005
    screwdriver and a mallet
    IS THIS SOMETHING YOU CAN SHARE WITH THE REST OF US AMAZING LARRY ?!?!?!
    aircooled VW FTW
    Glad to Be Alive
    quite being a girly man
    squeeze that fvcking tire together and break the bead,....show it who is boss....Even tires sealed for 6 months have broke free just squeezing them together violently
