Deity Decoy Pedals- Mtbr.com
Results 1 to 13 of 13
    Ancient Chinese Secret
    Reputation: Swell Guy's Avatar
    Jan 2005
    Deity Decoy Pedals
    Hey, my 2 month old Decoys self destructed on the trail today. The pedal slid right off the spindle. I did some trailside repair and figured out that the bolt keeping the bearing attached to the spindle undid itself. I wonder if there shoulda been some locktite on it. Also, looks like a metal band or bearing on the crank side was split down the middle, so I pulled it out to get the pedal back on. I think I need another one, what is it, a grease seal or bearing or something? Anyway, rolling without right now.
    I'm calling Deity tomorrow and find out what they say. Otherwise, seem like nice, thin, grippy, bomber pedals. Only thing I don't like so far (aside from self-destructing) is that the spindles do not have flat edges on them so I can use a pedal wrench for installation. I hafta use an allen wrench on the inside of the spindle adjacent the crank arms for install.
    they do have locktite on that nut, but you should have felt some play before they broke if the bearing broke. i don't know how you figured out a way to break them. the design is really well done. i don't know why you're complaining about not having to use a pedal wrench though, i love using allen keys
    but they'll probably send you a rebuild kit for free. they did when the nut on my pair stripped.
    Jan 2005
    Quote Originally Posted by nmpearson
    The bolt undid itself. The bearing didn't break, the nut simply threaded off. The bearing looks fine to me. Seems like would be easy to happen if there was no loctite on the spindle threads.
    What broke was a metal band on the inside of the pedal. Not sure what function that has.
    Ideas Above My Station...
    Reputation: Orange-Goblin's Avatar
    I saw a review saying the same thing the other day....
    ...i do not understand how this is a negative? Do you really wanna have to carry a wrench on the trail rather than the default allen key set? Wrenchs are a pain in the ass.
    I love my Decoys, i've lost a fair few pins now now, but if you hit a pedal hard enough/enough times, that will happen! They're kinda the right amount of grippy now with my 5.10's, bit too much with a full set of pins!!
    Not sure about the spindle issue, its pretty much the exact same Kona Wah Wah innards, and they're legendary. Give em a ring, they're good people.
    Its All Downhill From Here....!
    i don't know why you're complaining about not having to use a pedal wrench though, i love using allen keys.
    Wrenches are much faster.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Faster? So much easier to spin them on with an allen, and quicker IMO.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Meh.
    Reputation: XSL_WiLL's Avatar
    Call or email Deity. They'll take care of you.
    With a wrench and a bike in the stand, you start the thread and backpedal while holding the wrench on the flat. And then give the wheel a good backwards tug. The pedal is now nice and tight.
    However, an allen is not much (if at all) slower. And it convenient to not have to have a wrench with you. It tightens up just fine.
    Reputation: Cantil3v3r's Avatar
    Jan 2009
    definitely give Deity a call. I have dealt with them before on a set of bars and their customer service is top notch!
    Quote Originally Posted by kenbentit
    With a bike in the stand it's much faster to use a wrench, that's why bike mechanics in shops (myself formerly) use them. You should never have to tighten a pedal on the trail if you applied sufficient torque (another nice trait of a pedal wrench).
    Jan 2005
    My old DMR's have both allen and flat pedal wrench features so you can pick. I use the pedal wrench in the stand, but it would be nice to use an allen as a backup. I've never had a pedal undo itself from the crank arm though.
    Glad to Be Alive
    I l
    ike the allens...but it is 6 of one/half a dozen the other
    Pivotal figure
    Jan 2003
    I just hate having to dig that big ole pedal wrench out The only drag is having some pedals with 6mm and others with 8mm...
    Takw/agranofsalt
    Jan 2005
    Quote Originally Posted by gurp
    Allen wrenches typically are not as long as a pedal wrench. I.E. you can't put as much torque on the pedal when you install it or remove it.
    That being said...I like the option of using both.
