Deemax problem!- Mtbr.com
Results 1 to 5 of 5
Thread: Deemax problem!
    Reputation: BigBadHucker's Avatar
    Mar 2005
    Deemax problem!
    Okay i have had my deemaxs for a month now and i keep hearing metal rolling around in side the rim at low speeds. I'm figureing that its a piece of metal from when mavic punched out a hole in the rim for the spoke and got stuck in there. Anyone have this problem before and how did you deal with it. If i send it back to mavic I will have to wait like 3 weeks for them to check it and send me a new one or the same wheel back. I would rather not have to do that.
    Former Noob Herder
    Reputation: zedro's Avatar
    take off the tire and remove the valve stem, you should be able to liberate the piece from there
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Mar 2005
    Quote Originally Posted by zedro
    yea i did that and i tried shaking it out but its on the opposite side
    Former Noob Herder
    actually its probably the pin they use to hold the rim together before they weld it, not sure if you can get it out. You can always remove the eyelet thats closest to the sound, but really you should be able to move it around anyways if that would work.
    the target bike basher
    Reputation: puttsey's Avatar
    Deemax problem? Blasphemy
    Quote Originally Posted by mothahucker
    Go hit some more two foot plywood jumps in your culdesack on your toys'r'us magma
  1. Marzocchi Marathon SL knock sound problem
    By Avé in forum Shocks and Suspension
    Last Post: 02-11-2005, 10:58 AM
  2. WB's fork problem...
    By mdutcher in forum 29er Bikes
    Last Post: 12-11-2004, 11:20 PM
  3. Big big big brake problem....
    By AdamOn6thStreet in forum Brake Time
    Last Post: 10-15-2004, 01:33 PM
  4. Problem, Problem, Problem?
    By Mack in forum Shocks and Suspension
    Last Post: 07-13-2004, 08:41 PM
  5. Sugar 3+ Drive Train problem / question HELP!
    By mattstep in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-10-2004, 01:42 PM
