The death of my XO and DT Swiss wheel- Mtbr.com
Results 1 to 15 of 15
    If you think you can
    Reputation: 62kona's Avatar
    Well doing this on my nomad
    And this
    Resulted in this
    Busted derailure, hanger, 6 spokes and a bent chain link! Damn long cage xc ****! Definitely getting a medium cage.
    www.derbyrims.com
    Reputation: derby's Avatar
    Chain probably was too short for the gear it was in when it happened.
    When the suspension compresses, the distance from crank to axle grows, but the chain doesn't. When the derailleur cage can't take up any more slack the derailleur cage bends inward... catching a spoke and bang! Derailleur is sucked by the wheel.
    Ancient Chinese Secret
    Reputation: Swell Guy's Avatar
    Jan 2005
    Chain too short. Been there, done that.
    Some Assembly Required
    Reputation: man w/ one hand's Avatar
    Classic
    "Why are you willing to take so much & leave others in need...just because you can?"
    Glad to Be Alive
    Yikers !!!!
    eat your porridge jordie
    Reputation: jimmydean012's Avatar
    Are you running a long cage? Ditch that nonsense!
    "If you want to do something ordinary people can't, you have to be willing to do what ordinary people won't"
    Yup. It was a long cage. It was on the bike when I got it. Ill be getting a medium his time.
    Get a short cage x.9
    www.derbyrims.com
    The short cage with one ring does gives better chain tension for less slap or chain drop.
    The real problem is too short of a chain. The forever recommended chain length, big to big gears plus 2 links when travel is bottomed, cage length doesn't matter, is to ensure the posted problem doesn't occur by accidentally being in the wrong gear.
    J:
    Reputation: Deerhill's Avatar
    Dec 2009
    medium cage big/big
    had too much chain for my liking, had to put x7 trigger back on so this won't happen
    The Unaffiliated
    More importantly, did you eat dirt and catch it on video?
    No eating dirt. Landed it smoothly. Just heard a loud bang when I landed.
    Roll on Spring Time!
    Reputation: juan pablo's Avatar
    But if the chain was too short it would surely only be an issue if the the OP was in the lowest gear on the cassette? I have made my chain too short before but it was SS. I would think if the chain was too short and you were in the middle of the cassette then no biggy. I am sure the OP was not hitting stuff in the lowest gear?? When climbing it is unlikely to use full travel. Not that I am recommending making the chain shorter than it should be.
    I just want to ride.
    Reputation: adamm3's Avatar
    i have done this but not for any of the reasons above. I did the same thing with an X0 and DT wheel. Check the L limit screw and see if the black plastic insert is still there. Mine was gone and it allowed the der to drop into the spokes. 10 spokes, 3 pieces of der and broken hanger...no fun, but SRAM replaced mine for free thanks to my lbs
    no matter which size cage you use i would take the shock off and cycle the swingarm while in big and big
  1. DT Swiss XCR 1.5 as wheel upgrade?
    By montana_ben in forum Cannondale
    Last Post: 11-05-2010, 12:45 PM
  2. Wheel Death
    By CMu_dogtag in forum Wheels and Tires
    Last Post: 08-26-2009, 11:45 AM
  3. dt swiss 340 xc wheel set
    By kies1 in forum Wheels and Tires
    Last Post: 07-18-2009, 08:37 AM
  4. Lend me a 29er Rear Wheel For Julian Death March??
    By dezwilder in forum California - Socal
    Last Post: 04-13-2009, 09:24 AM
  5. Death of a wheel. Long and Newbish.
    By RonSonic in forum Wheels and Tires
    Last Post: 11-07-2005, 09:34 AM
