DD or Exo+ casing confusion, please help!- Mtbr.com
Results 1 to 3 of 3
    May 2020
    Sorry, I feel like the psi conversation has been beat to death. I have a more specific scenario though. I'm wanting to take my hardtail to the bikepark in a month or so. I currently have maxxis exo + tires, Assegai up front and minion in the rear. I believe the exo + is a single ply tire. I'm wondering what PSI i should use for the bikepark. I'm running tubeless, weigh 140ish pounds. I usually run 22 and 24 f/r for pressures at my local trails which can get pretty rooty and gnarly. I was thinking about putting a cush core in the rear but I don't want to deal with all the hassle, especially if i flat at the park. Would I be safe running maybe 3-4 pounds higher then I usually do? I see alot of posts about DH tire pressure, but usually theyre for people with dual ply tires. Any response is appreciated.
    i'm schralping yer thread
    I guess it depends on what park and what kind of trails; but yeah, in general your rims will thank you for adding some pressure. The sidewalls in those exo+ are going provide a lot less support than a DD or DH casing and at the higher speeds you're probably going to be doing at the park, you'll definitely notice.
    And yeah, they're kind of a PITA to install, but throwing cushcore or other insert in the rear is not only going to help prevent nuking your rim, but also will really improve the ride quality. The first time I ran them, I couldn't believe how much the cushcore smoothed out the trail chatter.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Go DH casing.
  1. 2 psi, 1.5 psi, zero psi......
    By Jeff_G in forum Fat bikes
    Last Post: 01-27-2018, 04:54 PM
  2. Maxxis, Minion DHF, 26 x 2.5, EXO single-ply reinforced sidewall
    By CrashTheDOG in forum Wheels and Tires
    Last Post: 10-11-2011, 05:12 PM
  3. Kenda BBG Tire Review - 2.35 DTC single ply
    By marshalolson in forum Wheels and Tires
    Last Post: 08-01-2011, 07:27 PM
  4. 2.5 Single-ply or 2.35 2-ply?
    By Rickee in forum Downhill - Freeride
    Last Post: 01-09-2007, 08:12 AM
  5. 1-ply tires with DH tubes or 2-ply tires with regular tubes?
    By phUnk in forum Downhill - Freeride
    Last Post: 06-01-2005, 04:34 PM
Members who have read this thread: 31
