Cutting of the stearer tube- Mtbr.com
Results 1 to 8 of 8
    Reputation: crappylatay's Avatar
    Im gonna be getting my new granmal frame in the mail this monday so im gonna start ordering parts to get my fork on, but the steering tube on my 888 looks like its gonna be alittle long, do you have to cut them?Do any of you guys know of what chainguides will fit on the granmal, blackshire DS-1 NS-1?
    thanks
    Road/XC/Freeride
    Reputation: Ace1's Avatar
    Often.
    Always tryout spacers first to see how you like it. You can always cut a little more off but you can't add a little on!
    I'm on the Twitter.
    how do you ride yours?
    Pain Is A State Of Mind
    Reputation: free-rider_down-hiller's Avatar
    Jun 2005
    .......BIKE SHOP would be good for you!
    Opportunity awaits those that are worthy....
    Photamagrapher---http://gallery.photographyreview.com...&ppuser=244688
    I wear two thongs
    Reputation: Eric Hoefer's Avatar
    If its only a little bit too long say 1-2 inches or so you can get some spacers and place them underneath or on top of the stem (or a little bit of both to get the stem height to your liking. then If you want you can cut off the excess removing the need for the spacers above the stem, or you could just leave it long and have more stem height adjustability. If you go the cutting route I used one of these to cut my steer tube and just took my time so I didnt damage the cutting wheel.
    Hiking is just walking where its okay to pee... Sometimes old people go hiking by accident. -Demetri Martin-
    Shwing
    Reputation: nano5467's Avatar
    also if your going with cutting it yourself, a dremel or hacksaw work well
    Nothing Else Matters...
    Glad to Be Alive
    Quote Originally Posted by Eric Hoefer
    don't cut the stearier tube untill you have it on your bike.....find exactly how long you want the tube first......
    then for the cleanest and straitest cuts..... use a pipe cutter (picture above) that is the best way
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    werd
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
