Crank Issue- Mtbr.com
Results 1 to 6 of 6
Thread: Crank Issue
    Crank Issue
    I've got an 07 sx trail and I'm having issues with the hussefelt cranks that came on it. The crankbolt on the drive side keeps coming loose. I've read that people have had the same issues but I was wondering if there is a way to fix the problem. Thanks.
    "Roads? Where we're going, we don't need roads."
    clyde in training
    Reputation: 08nwsula's Avatar
    loctite
    moaaar shimz
    Reputation: tacubaya's Avatar
    Blue* loctite
    Thats what i was thinking but i wasnt sure it would be safe to use. thanks.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Make sure to clean the surfaces that the loctite will be applied to.
    DIRTYAMERICAN
    Do you have external bearings on your bottom bracket? If you do LOOSEN the non drive side first, THEN tighten the drive side, use locktite if necessary, THEN tighten the nondrive side. This will allow you to fully tighten the drive side. I had this problem just recently and being new to external bearing bbs (yes, I know I'm behind the times but I don't buy new parts until they break) ..I just learned on my own what's up with them.
    let's roll
