Crank Installation- Mtbr.com
Results 1 to 15 of 15
    Crank Installation
    I just bought a new crankset and bottom bracket and was wondering how difficult it would be to install myself? I have probably a little less that average experience working on bikes, but if I bought the right tools, how hard would it be? I would like to start learning some more about workin gon bikes.
    Glad to Be Alive
    it is easy if you are mechanically minded
    Its VERY easy yet a lil tricky...the drive side on the bottom bracket shell is reverse thread so it spins backwards to what you think it should other then that its pretty much take off put on nothin to it should take you all of 5-6 minutes
    Meh.
    Reputation: XSL_WiLL's Avatar
    Not difficult, grease up the shell like crazy, plug any holes in the shell with lots of grease. The other day, I poured a shotglass full of water out of my seattube. It would've been in my BB shell if I hadn't plugged the hole with grease.
    Wrap the threads of the cups in about 3 layers of white plumbers tape. Grease generously.
    Drive side is reverse threaded. Thread em in nice and tight, use a torque wrench if you got one.
    Excellent guys. Thanks for the help. Are there any special tools I'll need for the bb or anything or should I have them all in my tool set already?
    Reputation: Amazing Larry104's Avatar
    Aug 2005
    you proabably need a bb tool. theres a couple different kinds. make sure when you tighten it you push it down really hard because its easy for it to slip and mess up some of the metal on the bb
    IS THIS SOMETHING YOU CAN SHARE WITH THE REST OF US AMAZING LARRY ?!?!?!
    aircooled VW FTW
    Meh.
    You'll need a crank puller and a bb-tool. Make sure you get the proper crank puller, there's one for regular square taper cranks, and one for use with bb's that have hollow axles, like ISIS or Octalink. You'll also need the proper bottom bracket tool. There are a few different ones out there, make sure you get the right one.
    which crank, and bottom bracket is it?????
    is it an external bottom bracket?
    Glad to Be Alive
    Quote Originally Posted by massmang
    dats what I am saying....which brand
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    Its also easier to take out the right cup first, and then the rest of the BB as a whole. If thats how it is....
    Cup first, not sure which side its on lol
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    The cup is on the left side.
    Disco-Superfly
    Quote Originally Posted by mtb_biker
    I typed left the first time, then erased it and put right........
    I just went and looked at my old BB and the cup is on the left
    Left cup out first, then the rest of the BB is the easier way...
    Jake
    Yeti 303 WC 25th
    If you do things right the first time you will avoid the pitfalls that notoriously follows hack jobs
    -squeeking, creaking etc etc
    truvativs bbs require 30ft lbs of torque per cup(torque is different dependant on the manufacturer) brand new bbs usually have an antisieze applied to the threads in the middle. though I always apply 242 loctite to the threads of metal cups(first 3 threads) this is enough the maintain the bb cups in place to prevent creaking, or loosening off. grease is temporary and only seems to muffle the inevitable.
    As per the wize guy who plugged his holes in his bb shell with grease, the hole is meant for condensation collected within the frame to drain out. Not so much a problem for aluminum frames, but the bb on the other hand.
    Get a torque wrench, borrow a torque wrench and follow manufaturer installation(some fat guy didnt just type them out for you to throw them away)
    Disco-Superfly
    My GP team DH thinks its funny to creak and crack... I just got a BB tool now to find a crank pullerrrr
    Jake
    Yeti 303 WC 25th
    Meh.
    Wrap your BB is white plumber's tape several layers thick. It helps with the creaking and clicking.
