Couple of stupid questions but hey....- Mtbr.com
Results 1 to 16 of 16
    Reputation: MTBSully's Avatar
    Sep 2004
    srry guys this is probably a pretty stupid question but, what is the difference between mechanical disk brakes and hydraulic disk brakes? What are the pluses and minuses?
    Also what is the little cylider above some rear shocks? What does it do and how does it help?
    Sully
    Former Noob Herder
    Reputation: zedro's Avatar
    mechanicals: cheaper, use standard levers and cables so repair is easier
    hydrolics: better feel, better modulation/power (depending on system)...if you put a premium of braking performance, these are what you get
    that reservoir on the shock is called a piggyback (ones that are detached are called remote reservoirs). Its a chamber that allows the oil to be displaced by the shock piston through the stroke (ie. the chamber has a piston that seperates the oil and air pressure). It also can introduce some damping functions to the shock depending on the design.
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Cynical Bystander
    Reputation: COmtbiker12's Avatar
    Also hydraulics generally require less maintainance once setup properly.
    Tony
    is making a comeback.
    Turns out that five years of not mountain biking, really makes one strive to get back to it.
    Former Noob Herder
    Quote Originally Posted by COmtbiker12
    and they attract more and better quality chicks....
    ....oh there i go multiplying zeros again
    Glad to Be Alive
    they also feel smoother and nicer
    Sep 2004
    Quote Originally Posted by zedro
    haha, thanks guys
    Sully
    Stand back
    Reputation: dbabuser's Avatar
    what are you referring to?
    Quote Originally Posted by SHIVER ME TIMBERS
    Your avatar or disc brakes?
    Well set up mechs can be pretty smooth.
    Golden Bike Park
    Golden Connector Trails need your support!
    you also do not have to worry about the cables stretching on hydraulic, but if you squeze the lever with no front wheel on it screws them up and is a pain to fix. it is because they are self adjusting
    Reputation: norcalbike's Avatar
    Dec 2004
    It also might help to know that hydraulic brakes use hoses and fluid.( hense the name "hydro") Sometimes this can cause problems like leeks and air in the system.Generaly hydaulics are better and more energy efficient tho.
    Jm.
    Jm. is offline
    Reputation: Jm.'s Avatar
    Hydros; Less maint, better feel, better heat dissapation (less fade), my hydro pads don't seem to wear down nearly as fast as mech ones (most likely due to the heat dissapation).
    Mechs; Cheaper.
    Those are the advantages of each. All other catagories are debatable untill the cows come home (like which is easier to set up, and I know examples of both that are easy and hard).
    I know in my heart that Ellsworth bikes are more durable by as much as double. AND they are all lighter...Tony Ellsworth
    Stand back
    you forgot one other
    Quote Originally Posted by Jm.
    Mechs; Cheaper.
    another advantage for mechs - more adjustable. They may be making strides w/ the Juicy and El Camino, but still no hydro offers power/ modulation and lever pull adjustments.
    Golden Bike Park
    Former Noob Herder
    Quote Originally Posted by dbabuser
    well just about every hydro has a lever adjustment at least. As for the power/mod adj., not all that usefull IMO...i just want the most power and i'll get used to modulating it. And not much of an advantage if hydros have more power anyways.
    Stand back
    hydros have lever reach, but not pad engagement point adjustments. And from what I've heard, the power advantage is debatable. I haven't owned a set of hydros (altho I've worked on them a fair amount) and I won't rule out owning a set on my new bike, but they will have to kick ass and not cost and arm and a leg...
    Golden Bike Park
    Cynical Bystander
    Used hydros is where it's at.... I mean other than a bleed and maybe a new set of pads, as long as its in working order its all good.
    Tony
    Former Noob Herder
    but also very real. For one thing, brake fluid isnt compressible, but brake cable lines do stretch. Then theres the heating/brake fade issue.
    when was the last time you saw a car with mech brakes?
    Stand back
    that's what 8" rotors are for
    I'm 190 w/o gear, haven't noticed fade with my 8" fr/ 7" rr Avid mechs downhilling all day at Keystone, Vail, WP. I can't say as I've ever felt the need for more power, either. Maybe I'm not dragging my brakes enough?
    You're not going to get cable stretch unless you are at a mechanical disadvantage and have to really torque on the levers. Due to the leverage they provide, I can brake w/ one finger, and I don't think I'm strong enough to stretch a cable with one finger. If cable stretch does occur, it only is a finite amount, and is easily adjustable, not that I've ever noticed or had to adjust for it.
    Also never seen a 40 lb car.
    Golden Bike Park
  1. Just a couple questions...
    By Captain Snakebite in forum General Discussion
    Last Post: 11-13-2004, 07:30 AM
  2. future 5 spot owners stupid questions
    By newton in forum Turner
    Last Post: 05-12-2004, 02:11 PM
  3. Couple of blur questions
    By cowdog in forum Santa Cruz
    Last Post: 05-10-2004, 04:04 PM
  4. A couple more questions
    By ghr7891 in forum Downhill - Freeride
    Last Post: 03-19-2004, 11:29 PM
  5. Replies: 8
    Last Post: 01-20-2004, 03:20 PM
