Correct spring rate for SPV shock- Mtbr.com
Results 1 to 12 of 12
    Authority is dead!
    Reputation: Lucky13's Avatar
    Sitting here and guessing how to pick correct spring for FR (some DH). Any formulas exist?
    For the love of Oi
    Rent a house at Attitash
    Are you talking to me?
    Reputation: damion's Avatar
    Jun 2003
    I dont remember it.
    Quote Originally Posted by Lucky13
    Someone will chime in with the formula. They are going to need the shock stroke, the amount of travel, and your body weight.
    gfy
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    Quote Originally Posted by damion
    Someone will chime in with the formula. .........................
    it's easy....
    too stiff = lighter weight spring
    too soft = heavier weight spring
    wheeeee!!!
    Reputation: butocabra's Avatar
    Used to have a spreadsheet set up, but here's what it comes down to, with examples.
    take the stroke of the shock
    2.0 "
    take the stated travel of the bike
    6.0"
    that gives you the actuation ratio:
    6/2 = 3:1
    take the desired sag
    30%
    and multiply it by the stroke of the shock:
    30% * 2 = 0.6 inches.
    take you weight
    150 lbs.
    each pound of your weight will be multiplied by the actuation ratio. and springs are rated in pounds/inch. so a 500# spring will compress 1" for every 500 lbs.
    so (150lbs * 3 ) / 0.6" = desired spring rate / 1.0"
    simplifying we get
    450lbs / .6 = spring weight
    which yields 750# as the ideal spring rate for a 30% sag.
    At least that's how I figure it.
    Reputation: I_8_It_up's Avatar
    Quote Originally Posted by butocabra
    2.0 "
    6.0"
    6/2 = 3:1
    30%
    take you weight
    150 lbs.
    simplifying we get
    Can you do mine for me I suck at math...
    230lb guy, 8.5 x 2.5, only want 25% sag.
    LT1
    LT1 is offline
    You forgot something VERY important...
    ...full body weight is not 100% distributed to the rear wheel. Remember, you have 2 wheels.
    Generally, I split the person's weight 1/3 to the front and 2/3 to the back.
    Also, these formula's don't take into account the characteristics of the shock. They can make a difference. Or any rising/falling rate of the actual linkage.
    Although I do use the formula's, I generally use them as a guideline for picking springs when I already know what spring is on the bike already, what kind of bike it is, what kind of shock they currently have, and what kind of problem the rider is having.
    Picking new rear springs is part math, part trial and error, and part experience.
    LT1
    LT1 is offline
    And believe it or not folks...
    Quote Originally Posted by .WestCoastHucker.
    it's easy....
    ...in many cases, this is what it really comes down to...
    Quote Originally Posted by LT1
    This is my ride, shock is a pro pedal.
    LT1
    LT1 is offline
    What is the spring rate you have now ?
    It will be on the side of the spring, it will say something like "550x2.25".
    550 x 2.80
    yep...550 x 2.80
    wheeeee!!!
    whoops
    yep, right you are. I forgot about the weight distribution part. so 2/3rds of rider weight on the back. seems right. maybe it should be riderweight * sin(seat angle) (kidding)
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. What spring rate 03 Turner DHR w\Romic
    By RickyD in forum Downhill - Freeride
    Last Post: 04-01-2004, 07:33 AM
  3. Heckler- What spring rate is right for me?
    By fasteddy001 in forum Santa Cruz
    Last Post: 03-31-2004, 08:46 AM
  4. K2 Razorback Noleen Mega Air rear
    By MegaVolt in forum Shocks and Suspension
    Last Post: 03-30-2004, 09:28 PM
  5. How does rocker length relate to shock spring?
    By jennasdad in forum Turner
    Last Post: 02-26-2004, 11:54 AM
