Converting QR Hope Pro 2 to bolt on?- Mtbr.com
Results 1 to 11 of 11
    Its got what plants crave
    Reputation: Jim311's Avatar
    Feb 2006
    Now that I've got a 20mm fork in the front it seems natural to try and find something stiffer for the rear hub as well. Is there a bolt on axle kit? Right now it's just quick release, 135mm. What all is entailed in the conversion? I assume some kind of cups in the hub itself have to be changed out? Will I gain enough stiffness to make this worthwhile?
    ...idios...
    Reputation: SteveUK's Avatar
    You'll need to switch the axle, here's the CRC page. I run the bolt-on on my Big Hit and it's plenty stiff. The Allen interface on the bolt-head is a little soft, in my opinion, so invest in a couple of top quality 6mm Allen keys, or be prepared to replace the bolts every once in a while.
    Here's a video from Hope describing how to dismantle the hub...
    <embed src="http://services.brightcove.com/services/viewer/federated_f8/1408014929" bgcolor="#333333" flashVars="videoId=1445041178&playerId=1408014929& viewerSecureGatewayURL=https://console.brightcove.com/services/amfgateway&servicesURL=http://services.brightcove.com/services&cdnURL=http://admin.brightcove.com&domain=embed&autoStart=false& " base="http://admin.brightcove.com" name="flashObj" width="486" height="320" seamlesstabbing="false" type="application/x-shockwave-flash" swLiveConnect="true" pluginspage="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash"></embed>
    Diogenes
    Feb 2006
    Thanks for the link. Do I order 10mm or 12mm?
    ...idios...
    If you're currently using a QR, I expect that you have 10mm dropouts. Which frame do you have?
    Diogenes
    Feb 2006
    2005 Kona Coiler. Wish I could convert it to a true through axle! Figured bolt on would be the next best thing.
    cgd
    cgd is offline
    Reputation: cgd's Avatar
    hope do a 10mm bolt thru axle conversion.
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    the link posted above was just a replacement through axle...here's the link to the conversion kit
    http://www.chainreactioncycles.com/M...?ModelID=11825
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    Brackish
    Reputation: carbuncle's Avatar
    Dec 2005
    I just got the 10mm conversion kit, thanks for the vid link!
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    A similar question... only for the front Hope Pro 2 hub.
    Is it possible to somehow adapt one for a 9 mm thru-bolt, like DT Swiss RWS? Hope doesn't yet make an adapter kit. But I think it may be possible to get a Hope Pro 2 front QR adapter kit, remove the protrusions that go into the fork dropouts and drill out 9 mm holes through the center of each adapter. Am I correct?
    Feb 2006
    I think I have heard of people doing that but I really don't have any details about it.
    meow, meow.
    Stupid me. I should just have googled it up:
    http://forums.mtbr.com/showthread.php?t=460766
    http://www.socaltrailriders.org/foru...front-hub.html
    From that thread, it turns out that Hope is going to make 9 mm thru-bolt end caps very soon.
