Converting 9mm rear hub to 10mm- Mtbr.com
Results 1 to 7 of 7
    NICE KID...NICE
    Reputation: wookie freeride's Avatar
    Need some help here. I have a wheel set that I am trying to use on a bike with 10 mm drop outs. The rear hub is currently a shimano Viam 9 mm QR and I want to convert it to 10 mm. I have taken apart the hub and I know I need to replace the cones as well as the axle. Is there a conversion kit out there that will accomplish this or do I need to do this piece by piece? Any suggestion would be greatly appreciated. If it is to much of a pain in the azz, I might just get a new hub and rebuild the wheel.
    mmmm, caffeine!
    Reputation: Noonie's Avatar
    Feb 2006
    Nice avatar.
    Ricky DH
    Reputation: rep_1969's Avatar
    Quote Originally Posted by Noonie
    Nice avatar.
    Nice Avatar . . . Billy Talent rocks!!
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    your rear axle is already 10mm's. just thread out the hollow axle and thread in the solid one...
    Meh.
    Reputation: XSL_WiLL's Avatar
    Make sure the replacement axle is the same diameter and thread pitch.
    Maher-Shalal-Hash-Baz
    Reputation: KennyO's Avatar
    If the existing 9mm axle is threaded, you should have a couple of bushings threaded to screw over the ends of the axles, then have them turned down to a 10mm outside diameter. Then you won't have to swap out axles or bearings, or anything else.
    This election is like a turd in a bag on your porch... whether its a blue bag or a red bag, it's still a turd on your porch.
    Pro Crastinator
    the shimano rear qr axle is a 10mm axle, it's just not a bolt on...
