clickin noise in headset- Mtbr.com
Results 1 to 11 of 11
    kona-tize me captain
    Reputation: austinb89's Avatar
    i just got a kona stinky and i put the drop off triple in the headtube with headset. it was all done at a lbs. and i have the fork set up nicely. but everytime i land off a jump or drop, rear wheel first and the front wheel comes down it makes a weird click noise. is that just the fork doing what its supposed to be doing or ??? anyone know
    im just curious cuzz this is my first dual crown fork i normally ride hardtails
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    Quote Originally Posted by austinb89
    This happened to me too, everytime I hit a big bump or small drop or whatever, it sounded like my fork was bottoming out hard....
    but I found out what it was and it was really nothing
    what my problem was:
    the shifter and brake cables slapping on my frame.
    I moved them and problem solved.
    check if yours are close to your frame, than that just might be it.
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    Schmeow Productions
    Reputation: JBsoxB's Avatar
    what headset is it?
    my friend had the same problem when he swiched (sp?) forks...
    he got a new headset and it went away.
    Yo Paseo El Scream
    Reputation: BansheeHucker's Avatar
    Dec 2004
    on my p.2 i had a lbs put a drop off triple and it did the exact same thing! i dont' know what it is, but i believe it's something wiht the fork
    Banshee Bikes
    Honorary Member Of The 200 Club
    Sponsers
    SixSixOne
    Soul Cycles
    Kenda Tires
    Quote Originally Posted by BJ-
    ..."if i can jump it on my feet whilst running as fast as i can, then it aint worth jumping on a bike"...
    Chinky on a Stinky
    ya its def the fork, I used to have DOT and it made same clikin noise when the front wheel hits ground after the rear wheel
    Straight outta Compton..............
    Team Tony Train - FR/DH Forever!!!!
    Sponsors: White Devil Syndicate (we're workin on it 'aight?)
    DREAM THEATER
    Generation X freerider
    Reputation: cdog117's Avatar
    send it in to marzocchi see if they can help, otherwise id get a new fork, if it afects the preformance
    alright thanks, i was worried it was gonna be huge, hopefully it is just a cable clicking. i dunno what else it could be the fork comes know where near bottoming out at all, but if it is the fork which hopefully it isnt ill try to get a jr t or something
    Quote Originally Posted by Chikity China
    what did u do with ur fork then trash it and get a new one?
    Chinky on a Stinky
    wut do you mean? what type of riding i do with the DOT? DJ, FR, no DH
    other than that, the clikin noise shouldn't be too much of a problem unless you have sensitive ears
    DREAM THEATER
    what type of riding did u do with the fork and then did u sell the dot or hang it up on the wall for laughs
    Glad to Be Alive
    Probably headset....change that first then see if the problem goes away...if not then send in fork
    Most likely headset
  1. Fox Vanilla Forx - noise coming from damper knob... anyone?
    By frank n. beans in forum Shocks and Suspension
    Last Post: 09-03-2006, 06:55 PM
  2. Strange noise when riding
    By some_guy282 in forum Beginner's Corner
    Last Post: 10-29-2004, 08:31 AM
  3. clickin noise?
    By doubleA's in forum Shocks and Suspension
    Last Post: 08-17-2004, 09:30 PM
  4. _ILLOGICAL_ drivetrain noise
    By Vic in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-07-2004, 12:43 AM
  5. 888r clickin noise
    By [email protected] in forum Downhill - Freeride
    Last Post: 03-20-2004, 03:03 PM
