Changing Travel on Marzocchi 66 RV (OEM)- Mtbr.com
Results 1 to 2 of 2
    Feb 2010
    These forks (Marz 66 RV 2007) came with my 2007 SX Trail 1. Does anybody know if they can be moved from the stock 160mm to 180mm and if so does anybody have instructions?
    I've had a search through the forums and not found anything on these forks (plenty on others!).
    Cheers.
    ...idios...
    Reputation: SteveUK's Avatar
    The guts are different. I investigated doing the opposite - 180mm to 160mm on my '07 RC2X (same rebound cart as the RV, I believe) - and found I would need to replace the cartridge in each leg to a the smaller version. If you can find the carts for cheap, the stanchion assembly is the same on 160mm and 180mm forks; so no need to replace them.
    Diogenes
