Chainguide help for Stinky Air- Mtbr.com
Results 1 to 6 of 6
    So I have a 2008 Stinky Air, which Kona failed to put ISCG tabs on. It has a 73mm BB shell, which means only one spacer on the drive side bb. Therefore, I substituted the BB spacer for an ISCG adapter. I'm using '08 XT cranks with the chainring mounted inside of the spider and a bashguard on the outside. I'm also mounting up the e.13 SRS guide. When everything is tight, the small chain ring mounts rub the back plate of the guide causing the cranks to not turn smoothly. I'm hoping to avoid grinding the crank tabs down. Any fixes?
    Any help on solving this problem is appreciated.
    Oct 2007
    i removed a spacer from the ISCG mounting bolts...but im assuming ur not using any right?
    grinding is the solution i know of. just find a buddy with a dremmel.
    Chillin the Most
    Try flipping the ISCG adapter around. Most ISCG adapters that I've seen/used have one side that is flat and the other recessed, try using the flat side out.
    Quote Originally Posted by brillantesdv
    That is correct, not using any spacers on the ISCG mounting bolts.
    Former Ninja
    Hey Mqt,
    My 2006 Stinky is more or less the same for a chainguide setup, so here is what I have.
    ISCG bb mount flipped inward followed by a 0.5mm disc brake caliper spacer (they're perfect for super tuning chainlines) and then the Wide angle backplate.
    The Stinky has dropped chainstays, so while the standard angle version works the WIDE angle version fits JUST right.
    Since you are running a single ring chainguide up front, the only real way to get it to clear properly is to remove the granny tabs. This is extremely common in the DH race circuit, and most of the time doesn't ruin resale value either. If you do end up taking down the tabs, the fastest and easiest way is to use a big old drill bit and drill them down perpendicular to the cranks. Soft aluminum goes quick, so just take it easy and clean it up with a file or some sandpaper.
    *edit* Just so you know, the LG1 and the SRS use the same backplate, so spacing should be very similar. Your spacing will also vary slightly with different types of cranks. I have 2006ish Truvativ Holzfellers.
    Cheers,
    philip @ e*thirteen
    Natl. Champ DH Poser/Hack
    Reputation: cactuscorn's Avatar
    Quote Originally Posted by philw86
    thats cool to know. thanx as usual phil.
    No, I'm NOT back!
