Chainguide/Crankarm Compatibility Question- Mtbr.com
Results 1 to 5 of 5
    ...abuse these forks.
    Reputation: dirtydownhill's Avatar
    Is the offset in a crankarm made for a triple ring setup the same as a single ring crankarm? If I take off the inner ring can I run it in a chainguide made for a single ring without grinding off the inner tabs?
    Dont pinkbike my mtbr
    sometimes, but I'v had to grind off the inner tabs on my cranks and my friends, not really a big deal though
    Reputation: wickedracin's Avatar
    Quote Originally Posted by dirtydownhill
    You should have to grind off the tabs, even the Truvative DH cranks still have the post in them.
    Meh.
    Reputation: XSL_WiLL's Avatar
    I run my double/triple Saints with just the middle and bash with a e13, I ran my dual Big Earls with a e13. I didn't have to grind off the mounts on either of them.
    Bike Ninja |||
    Reputation: chooofoojoo's Avatar
    Feb 2007
    You have to grind off MOST crank's tabs in order to have it close enough to the e13 plate to be effective.
    a few exceptions to this are saints, diabolus (has a cool little removable tab thing), and some bontrager stuff. i think hones you don't have to either...
    Proud to represent Mojo Wheels.
