Chain tension / MRP question- Mtbr.com
Results 1 to 8 of 8
    Kill that $hit!
    Reputation: MorphineAddict's Avatar
    I'm thinking of changing my rear derailleur over to a short cage derailleur to get better clearance and keep it out of the way. My question is.... if I do this, how much is it going to mess w/ my chain tension w/ my MRP?
    Glad to Be Alive
    Quote Originally Posted by MorphineAddict
    I am pretty sure you will need a road cassete to match up with it
    Kill that $hit!
    Quote Originally Posted by SHIVER ME TIMBERS
    I think that the Ultegra 9sp matches up, but I'm not positive.
    Kill that $hit!
    I think that the Ultegra 9sp matches fine w/ my cassette, but I'm not positive.
    Kill that $hit!
    Okay, really, I'm curious. Will it f*ck w/ the bottom tension roller of my MRP? Like will it be semi useless?
    Canfield Brothers
    Reputation: flymybike's Avatar
    From MRP
    When you buy your short cage it lists the cog capacity. Just be sure your cog set is no larger than what the derailliur is designed to work with. Shimano shorts cages fit 29 teeth. This will not affect your MRP at all. You may want to shorten your chain if your reducing teeth but insure you have enough chain length so if you bottom out (full Susp) your derailliur isn't being pulled too tight. ie breaking your chain, derailliur or ripping off your lower pulley on your MRP guide.
    Cheers
    Lance Canfield
    MRP
    Kill that $hit!
    Quote Originally Posted by flymybike
    Cheers
    Lance Canfield
    MRP
    Awesome, thanks!
    Canfield Brothers
    Awesome, thanks!
    My Pleasure!
  1. chain question...Probably an old topic but...
    By yz400e in forum Singlespeed
    Last Post: 04-27-2005, 11:43 AM
  2. even with MRP chain comes off?
    By Endo pro in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-12-2005, 12:38 AM
  3. rookie chain tension question...
    By FoShizzle in forum Singlespeed
    Last Post: 03-30-2005, 06:16 AM
  4. MRP chain guide question....
    By FISHLEG in forum Downhill - Freeride
    Last Post: 02-13-2005, 04:08 PM
  5. using MRP to tension chain
    By MD Bullit in forum Singlespeed
    Last Post: 01-19-2005, 08:25 PM
