Which chain guide are you guys runnig in your Bullits???- Mtbr.com
Results 1 to 14 of 14
    New question here. Which chain guide are you guys runnig in your Bullits???
    I have 3 rings right now.I want to get a chain guide Wich one you guys think is the best for a Bullit.Do I need to get a bigger B/B? Thank you for your help....
    I run a Heim 3Guide on my Bullit and it works perfectly. I run it using 2 rings and a bashguard. You can use this guide with 3 rings as that is what it was really designed for. Heim makes a 3 ring bashguard that is pretty sweet too. I've never dropped a chain. Prior to getting this guide I dropped my chain fairly often on rough downhill sections.
    NS1
    NS1 is offline
    Quote Originally Posted by cheloco
    I ran an Evil DRS on my Bullit, fitted on fine using the same 113/68 BB.
    Reputation: gonzostrike's Avatar
    BlackSpire Dewlie with 2003 Shimano XT hollowtech crankarms & BB, works like a charm.
    it's a 2002.5 Bullit, same config as 2004
    Absurd
    Reputation: MVRIDER's Avatar
    E.13 SRS w/38 t ring.
    the mrp
    yea the mrp dual slalom one, a bit smaller, but it fit great
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    none, i just told my bullette' not to drop the chain, so it dosen't
    jibber of the unjibbable
    Reputation: Cooter.'s Avatar
    any one of em that matches my panty pink bullit
    Boogie down to free James Brown
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Screw the Heim. Weyvoless has one on his Weyless. He lost his chain to the OUTSIDE Saturday during one of his race runs....
    I run an MRP LRP w/ 2 rings and bash gaurd.
    Did 3 race runs and 3 practice runs, never lost the chain once. Pretty good for a 2 ring set up.
    Whoaohohohoh
    Guest
    Bumping an old thread instead of making a new one.
    I dont have a lot of money to buy the evil DRS but I am having problems keeping my chain on. I looked today at my bottom bracket area and the chain did a number on the paint in that area as well as trashed some of the aluminum down there.
    My question is this, will the HEIM 3Guide help me from losing my chain towards the inside, ie droping it off the smallest ring onto the frame/bottom bracket area? or is mostly for helping to stop losing the chain towards the outside biggest ring?
    I read the mix reviews on this item and its only like 60 buxs at pricepoint so I am very interested in this item. BTW its going on a 2 ring setup with a bashguard on a bullit.
    Quote Originally Posted by Whoaohohohoh
    I run a Heim bracket w/ a MRP LRP roller - total cost was like $75. I don't like the Heim roller, doesn't like too much back pedalling.
    Feb 2006
    e13 SRS 42 tooth. incredible guide, i lost a chain ONCE during the first hour i had it on. i fiddled with things a bit and it never came off again. plus it's indestructible. definitely worth the dough (got mine for 120 i think?)
    Bum Buzzer
    Reputation: Huck Banzai's Avatar
    May 2005
    Quote Originally Posted by MVRIDER
    Ditto.
    Considering a DRS for it when it 'goes trail'
    "If it ain't EVIL, it's not nice!"
    Takw/agranofsalt
    Jan 2005
    This might be hard to see in the pictures but I have had good luck with a TruVative single speed crank that had a small bashguard on the outside of the ring that I moved to the inside with the help of several washers and added a Dangerboy bashguard to the outside. I have yet to drop the chain once and I'm not even running a roller. I guess this doesn't help if you plan on running more than one ring but I just wanted to share.
  1. Chain guide for Bullit
    By Ripzalot in forum Santa Cruz
    Last Post: 04-29-2004, 09:00 AM
  2. MRP Minime System 1 chain guide
    By gemi_adrenolin in forum Downhill - Freeride
    Last Post: 03-27-2004, 06:32 PM
  3. Chain guide for Monkey???
    By Trail Thumper in forum Downhill - Freeride
    Last Post: 02-10-2004, 10:16 PM
  4. MRP Chain guide and a Giant AC2
    By canada17 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-10-2004, 08:32 AM
  5. Replies: 2
    Last Post: 01-21-2004, 08:16 AM
