Chain guide for TRUVATIV STYLO SS CRANKSET?- Mtbr.com
Results 1 to 12 of 12
    Reputation: gtbikesalltheway's Avatar
    What would be a good Chain guide for that crankset for less than a hundred dollars, my chain keeps falling off
    Can't get right...
    Reputation: dannymonky's Avatar
    i've got the same crank. Are u running it as a ss or w/ gears? I have not really ridden it too much but have not dropped the chain yet and i'm running a der w/ it.I was also thinking of a chainguide for it. Lets see what other guys say about it.By the way what did u pay for the cranks?
    I watch the O.C. cause it makes me happy...
    If misery was money i'd be the richest man on the planet.
    Trials Superstar
    Reputation: RigidOne's Avatar
    seems like you need an MRP or if your cash is low a Truvativ chainguide from JensonUsa. Under a 100.00 too! If you arent running gears, I have had a lot of luck with the Surly Singulator
    Please purchase products from JensonUSA your #1 Internet Dealer for MTB parts!
    AS SEEN ON THE X-GAMES and GRAVITY GAMES! How would you like to go 80 MPH on a bike 4 inches from the ground? Well you can learn how at GravityBike.com the home for BMX Speed Machines!
    2004-2005 Sponsors
    Maxxis Tires
    Targert Sponsor
    Azonic
    Hayes
    yeh I have a rear der on it and it keeps dropping the chain like crazy and whenever I bunny hop or something the chain slaps the bottom of the bash guard make a loud annoying sound and I dont think its good for the chain. I paid like 120 for it
    Can't get right...
    The tru Vativ works good- i had it on another bike of mine. Maybe your chain is too long tho. Try taking a few links out.That might help a little.If not go for the chainguide of your choice- most will work.
    Trials Superstar
    Quote Originally Posted by gtbikesalltheway
    yep. a common problem. If you are cheap like me toss an old front derr. on there. It works to a little bit for going around town and jumping cats and such.
    2004-2005 Sponsors
    Maxxis Tires
    Targert Sponsor
    Azonic
    Hayes
    yeh I allready took out 2 but I will try more because that could be the problem I just switched the chain from an idrive to a steelhead. and how do you know if you took out too many?
    I have an old front der but I would rather just spend like 100 dollars to get it working perfectly
    would this work? http://www.jensonusa.com/store/product.aspx?i=CG707B00 I have no clue if the cranks are 104mm
    Can't get right...
    Put the chain on the biggest gear(lowest) and the der arm shold ALMOST be fully extended towards the crank. It should be about 2 links longer than having the der fully extended. hope this helps. By the way not sure if that chainguide will work 4 your crank-dont know the bolt pattern....
    what is fully extended? my der keeps going haha
    Can't get right...
    what is fully extended? my der keeps going haha[/QUOTE]
    With the chain in the biggest gear the part of the der that takes up slack (arm,leg...whatever its called) bends forward towards the crank. Sorry i cant describe it good but im watching monday night football and the beers im drinking are winning..
  1. chain guide blues
    By BiKeBaStArD in forum Downhill - Freeride
    Last Post: 09-23-2004, 12:46 PM
  2. Best chain guide for two chainrings?
    By raegeno in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-10-2004, 01:57 PM
  3. Sram chain shifting like arse on new XT hollowtech crankset
    By Srexy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-28-2004, 08:25 AM
  4. mrp chain guide woes.......
    By xterraman30 in forum Downhill - Freeride
    Last Post: 05-11-2004, 09:16 AM
  5. SS crankset...light?
    By Alan in forum Weight Weenies
    Last Post: 05-04-2004, 01:53 PM
