Cane Creek S2 strong enough for DJ/urban?- Mtbr.com
Results 1 to 8 of 8
    That one dude
    Sep 2004
    I need a new headset for my P.2, and was wondering if the cane creek S2 would hold up to the rigors of DJ's and urban riding? A few of my buddies ride them with no problems, but this headset isn't specifically marketed for this type of riding. I'd also like a FSA pig, but I'm not sure about dealing with unsealed bearings, seems like something extra for me to screw up when I install it. Any thoughts?
    @cjcrashesalot
    Radical Off The Statical
    Jun 2005
    there is a sealed version of the FSA Pig... i'd go with that... great headset for the money
    Clips are for kooks
    ridin' is my escape
    Reputation: SBSfreerider's Avatar
    May 2005
    i can agree with that, i had one when i bmxed
    _SouthBaySoldiers_
    Certified Moots Whore...
    Reputation: Something Clever...'s Avatar
    Feb 2005
    I use a Cane Creek S2 on my heckler and my chameleon without any problems... As long as you install it correctly and keep it clean and sealed you should be just fine...
    Juanjo
    Reputation: EastCoastHucker's Avatar
    Jun 2005
    I have the Pig in my HT and totaly recomend that HS... u can't get any better for 20bx.
    ~~~~~~~~~~~~~~~~~~ \m/>-<\m/ ~~~~~~~~~~~~~~~~
    Jesus loves you ............. Everyone else thinks your an A$$hole .
    That one dude
    Sep 2004
    Update, I just bought and installed a Pig (the unsealed version), and so far so good. The fork race was kind of a pain to get seated, but other than that, installation went fine.
    The main reason I asked the question was because I previously had an S2 which I bought used from a buddy, but after about a month, it went to hell. (LBS installed this one). I was wondering if it was the headset itself, or the installation/used part factor, since I was considering another one (they're quite smooth )
    Also, I got the Pig DH Pro (sealed) version for my DH bike, I just wanted a cheap solution for the DJ bike. Thanks for the replies
    @cjcrashesalot
    Reputation: Atomik Carbon's Avatar
    Fwiw.....
    DO NOT USE THIS FOR ANY TYPE OF AGGRESSIVE RIDING.
    I completely sheared off the bottom cup on a set of S2 while coming down a hill a few months ago. This should only be used for XC type riding.
    YaMon.
    gnar, brah
    Reputation: Andrewpalooza's Avatar
    Dec 2004
    Comparing the pieces of an S2 and a Pig should answer your question. I have intalled both of these, and, by far, the Pig is a more strongly build headset. The S2 looks super-precise and almost fragile by comparison. The crown race in particular looks really weak. The S2 is a a great headset in terms of reliabilty. The KU Mechanical Engineering team uses them in their Formula car to be the bearing on the rear suspension pivots. I wouldn't use them for dirt jumping though, after seeing the internals. The Pig is an indestructable headset, I can attest to that. Both of mine (one on a dirt jumping bike, one on an XC bike) have had zero problems other than regular maintainance, and I can assure you at least one of those headsets has been abused.
    Trestle Bike Park
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. Cane Creek WAM wheel?
    By ryman in forum Wheels and Tires
    Last Post: 08-09-2004, 01:58 PM
  3. Anyone using a Cane Creek Thudbuster, read this...
    By crashedandburned in forum Riding Passion
    Last Post: 06-18-2004, 07:20 AM
  4. Bearing Failure on Cane Creek Zonos Wheel
    By papajohn in forum Wheels and Tires
    Last Post: 04-23-2004, 11:10 PM
  5. Cane Creek air shock on Loco Moto?
    By jbf in forum Titus
    Last Post: 04-07-2004, 07:19 AM
