Can Hadley rear hubs be rebuilt ie 150/12mm to 135/10mm ?- Mtbr.com
Results 1 to 5 of 5
    I can get a slightly used 150mm/12mm Hadley rear wheel for a good price , but i need a 135mm/10mm rear. Are the Hadley hubs built so that I can just order a conversionkit
    ( say from Go-Ride ) and make it work (maybe with a redishing ?)
    Cheers Caspar
    Reputation: gonzostrike's Avatar
    Nope, I checked into this when I bought a frame with 150mm rear spacing. I already had a 135mm rear wheel with Hadley. Unfortunately Hadley said the hub bodies are totally different from 135mm to 150mm and there's no conversion. Sucks to have to buy another hub, but buy another Hadley.
    Quote Originally Posted by gonzostrike
    Ok txs .
    Now I just wonder what the conversionkits are used for then.
    Cheers
    Coversion Kits
    Quote Originally Posted by caspar
    Ok txs .
    Cheers
    The conversion kits allow you to change the axle from say bolt on,thru axle as well as axle diameter.
    Ok txs .
    Cheers
    The coversion kits are for standard width Hadley hubs. You can convert a Hadley SDH QR 135mm wide hub to a 10mm thru-axle x 135mm, 12mm thru-axle x 135mm, 15mm thru-axle x 135mm. The 150mm wide hub uses a wider hub shell (SDH XL). I have also had Hadley build up a 15mm thru-axle x 122mm wide flush mount for a customer using a Yeti with a floating brake and a 20mm to 15mm Yeti step-down axle.
    Erik,
    Balle Racing
    www.balleracing.com
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. New model Hadley rear disc may dethrone the King?
    By bianchi4me in forum Wheels and Tires
    Last Post: 08-15-2004, 05:07 PM
  3. what hubs? - Kings or Hadley or other
    By tax in forum Downhill - Freeride
    Last Post: 05-22-2004, 11:15 AM
  4. what hubs - Kings or Hadley
    By tax in forum Wheels and Tires
    Last Post: 05-21-2004, 07:43 AM
  5. Replies: 5
    Last Post: 03-31-2004, 06:58 AM
